Help! Weird Noise !!!
Old Apr 10, 2008 | 01:40 AM
cKranez's Avatar
when i put in my key on I the twist it to II before i start the engine my FIT makes this weird noise... sounds like an electrical / cloth tear or something.. under my FIT it does that every time .... is this normal ? and what is it ... the sound can be heard when i leave the door open and surronding areas have no sound... it's very noticable... should i be worried? ... thanks!
Old Apr 10, 2008 | 01:48 AM
spreadhead's Avatar
Two words.....fuel pump.
Old Apr 10, 2008 | 01:59 AM
tonyd3773's Avatar
Smile
Hey cKranez-
U could always take it to the dealer on your day off or something to check what the issue might be.....should be under warranty.
But to answer your question, no that is not normal
Old Apr 10, 2008 | 02:17 AM
cKranez's Avatar
sooooo a sentence... is it normal?.....
Old Apr 10, 2008 | 02:19 AM
spreadhead's Avatar
Yes it is.
Old Apr 10, 2008 | 02:23 AM
cKranez's Avatar
gracias...
Old Apr 10, 2008 | 02:24 AM
cKranez's Avatar
a fellow poster said its the fuel pump and its normal ... err who to believe!?
Old Apr 10, 2008 | 02:33 AM
claymore's Avatar
Fuel pump for sure and it's completely NORMAL. If you don't like to hear it there is only two ways to fix the problem... REMOTE STARTER or TURN UP YOUR RADIO.
ToFit2Quit's Avatar
Not normal. Usually, when you hear a noise like that, it means there's a loose connection in the circuit. In the long run, it's going to wear out the connection between the conductors. I would be worried if there were flamable gasses around.
Old Apr 10, 2008 | 03:46 AM
hondajazz2005's Avatar
i second claymore, i have that sound too since the day i got my car, and is on all my friends jazz as well.
Old Apr 10, 2008 | 04:09 AM
cKranez's Avatar
ok getting mixed answers imma probably go have it checked up couple days from now lolz. .... .worrying me thnx though guys
Old Apr 13, 2008 | 01:19 PM
Injundon's Avatar
Just like everyone's said it's just the fuel pump priming itself. The gas tank on the fit is between the driver and passenger seats, NOT in the rear of the car like most vehicles. So it's more audible than most cars.
Old Apr 13, 2008 | 04:56 PM
SAWYER's Avatar
Its seriously just the fuel pump. Its totally normal. Nothing to worry about.
Old Aug 14, 2010 | 12:46 PM
Jazz_Pinkz's Avatar
it's soooo normal.. just the fuel pump.. even that sound become my indicator that the system works well.. ^^
because i had a time when i didn't hear that noise, n that's right.. my fuel pump doesn't work, because a shorted fuse..
Old Aug 14, 2010 | 04:12 PM
Black3sr's Avatar
So worry when you don't hear it.
Old Aug 14, 2010 | 10:26 PM
Jazz_Pinkz's Avatar
yup.. you're right.. haha.. actually i hear the same noise in other car, but usually it so small in volume but you can hear it..
that's why i let that noise gone first then i start the engine..
Khaetra Sommers
Dec 3, 2018 05:16 PM
Martha Campagna
Nov 28, 2018 09:35 PM
nodelock
Oct 25, 2012 05:43 AM
pascoes
Jun 3, 2011 03:31 PM
super_fit
Jun 8, 2010 09:44 PM
