Need Help Asap
Old Apr 11, 2008 | 01:33 PM
dbcmaster's Avatar
Exclamation Need Help Asap - FIXED - NVM
Hey,
So, I'm doing the DIY add a light to the interior dome light mod. I splice in my wires and put the connector back on. Now, radio won't come on, interior lights won't come and the key won't lock or unlock the doors. I checked all the fuses and they are fine. Door lock/unlock works fine from the button inside the car. HELP!
DB
Old Apr 11, 2008 | 01:38 PM
Firebat666's Avatar
check the fuse box? thats all I got, Im no wiring expert.
Old Apr 11, 2008 | 01:40 PM
Illusive's Avatar
Did you disconnect a terminal on your battery before doing this mod? Maybe you forgot to put it back on?
Old Apr 11, 2008 | 02:29 PM
dbcmaster's Avatar
Battery is connected. However, I don't have anything hooked up to the tails I made off of the dome light connector. Would this cause an open loop in the system maybe?
****EDIT****
Scratch that... I just hooked up something to see if it was an open loop and it's not that.
Old Apr 11, 2008 | 02:51 PM
dbcmaster's Avatar
I found it. Of course it's the one fuse I didn't check. It's the Back Up fuse under the hood (10A). I re read the article and it said to check that. How did I miss this.
GRRRRRRRRRRRRRRRRRRRRRRRRr
BankWalker
Dec 22, 2015 09:18 PM
Packy
May 16, 2009 09:34 PM
trancedsailor
Dec 31, 2008 07:40 PM
sterVin
Nov 18, 2008 01:22 AM
espo79
Jun 30, 2008 03:52 PM
