Qestion for you guys with aftermarket lips
Old Apr 16, 2008 | 10:41 AM
Nerv2g's Avatar
I have been wanting to get a new lip for my car of course either j's or the mugen one. What I want to know from you guys is if this is just as simple as taking my sport lip of and putting the new one on. Thank you in advance.
Old Apr 16, 2008 | 11:19 AM
Illusive's Avatar
you'll need to drill some holes on the Mugen style ones and do some sanding to get it to fit properly.
Old Apr 16, 2008 | 01:22 PM
Nerv2g's Avatar
Can you give me a start as to what grit sanding paper to use? I guess installing would be pretty straight forward, correct?
Old Apr 16, 2008 | 02:26 PM
SD_MR_FIT's Avatar
no sanding involved with my lip.
i just had to dremel the extra lip that hugs onto your bumper by the wheel.
its something i didnt need.
but its pretty straight forward. screw two screws into the bumper on the sides to hold it onto the bumper. on each side that is.
so simple.
Old Apr 16, 2008 | 02:28 PM
Illusive's Avatar
It depends on which type you get. The one I have the problem parts are where they meet with the foglight housings. To fix this, I used a dremel with a drum sander and just removed a bit at a time and kept test fitting until it fit without rubbing. Install is pretty straight forward, if you have a Sport, you can use the factor screw and holes to mount the lip.
Old Apr 16, 2008 | 04:14 PM
Nerv2g's Avatar
Cool thanks guys, I wish we had more opitions. As I mentioned earlier I like the J's and Mugen but I wish I could get a lip that none ones else had.
Old Apr 18, 2008 | 01:41 AM
CuTeBoi's Avatar
Then you will have to make your own, otherwise someone else will always have it first.
Old Apr 18, 2008 | 02:47 AM
smatts's Avatar
Honda Fit Forums Moderator
Had to drill 2 holes for the J's Lip, all the other holes (about 8) were perfectly aligned. Dunno why there was 2 extra holes on the lip and on the stock bumper, maybe for extra support, its a bit heavier then stock.
Old Apr 18, 2008 | 03:24 AM
HondaFitted2007's Avatar
where did you guys buy the j's racing or mugen lip from? and what material (abs plastic, polyurathane, fiberglass, etc)
i know hondafittuner.com sells the mugen ones or i can get a carbon fiber one from seiboncarbon.com for an arm and a leg lol
Slasher
May 16, 2010 11:59 PM
chinkyy
Dec 8, 2009 01:47 PM
dmagic17
Aug 22, 2009 04:14 PM
volcom
Nov 12, 2008 03:30 PM
timandcake
Jun 25, 2008 08:07 PM
