hot civic no crank
Old Jul 22, 2005 | 07:31 PM
reid.maynard@gmail.com
Guest
Posts: n/a
hot civic no crank
hi
1991 civic dx, when hot (sometimes) stop to get gas; then no crank; all
lights, gagues, radio; can hear a relay <click-click> behind the radio
as I key into the starter position, but no starter action/noise at all.
All is normal otherwise.
Thanks,
Reid
Old Jul 22, 2005 | 08:47 PM
Professor
Guest
Posts: n/a
Re: hot civic no crank
Automatic or stick?
Automatic... check neutral start switch
Manual... check clutch depress safety switch
Professor
www.telstar-electronics.com
reid.maynard@gmail.com wrote:
> hi
> Thanks,
> Reid
Guest
Posts: n/a
automatic
you mean like the lever isn't all the way in Park or N?
if so, wriggled it quite vigoursly, unless the switch fails completely
when it gets hot...
Guest
Posts: n/a
I though more on this neutral start switch
after 14 yrs & 175k miles I think I just drop $35 on a new one
that will be less frustrating that trying to locate my ohm meter
thanks
Old Jul 22, 2005 | 10:45 PM
remco
Guest
Posts: n/a
<reid.maynard@gmail.com> wrote in message
news:1122073203.165246.5950@f14g2000cwb.googlegrou ps.com...
> hi
> Thanks,
> Reid
When you say a relay "clicks", you mean the solenoid sitting on the starter
under the hood? (loud clicks, being able to hear them from outside of the
car)
If so, most likely your starter is bad.
Old Jul 23, 2005 | 06:00 AM
Guest
Posts: n/a
the relay click is clearly somewhere in the dashboard area, doesn't
sound like the heavy starter solenoid, my click sounds very close to
the passanger area.
Philip May
Aug 8, 2017 02:29 AM
Sean McKenzie-Mardelli
Oct 14, 2016 03:02 PM
DCTepper
Nov 22, 2013 07:41 AM
mmdir2002@yahoo.co.uk
Aug 4, 2005 06:30 AM
Pailyn
Jul 3, 2005 04:05 PM
