HONDA CAR PICK-UP
Old Jul 26, 2005 | 09:32 PM
sonal83
Guest
Posts: n/a
HONDA CAR PICK-UP
I have a 1992 honda- I did fuel injection cleaned and tune-up .change air
filter,oil changed .used high octane gas,still car not pick-up when I give
to gas.?can you advise me or how to fix it?I will be appriciate your early
response thanks dinesh patel.NOTE: use to be a good pick-up but recently
it's poor.!!!thank again
Old Jul 27, 2005 | 12:33 AM
Nightdude
Guest
Posts: n/a
Re: HONDA CAR PICK-UP
could be plugged EGR or a plugged catalytic converter (happened to my dad on
his 89 accord).
"sonal83" <vnd74@yahoo.com> wrote in message
news:3e5385dba59949fbefb4207a3df4bd73@localhost.ta lkaboutautos.com...
motsco_ _
Guest
Posts: n/a
> his 89 accord).
If the timing belt is way overdue (years OR mileage) it could have
jumped a tooth or two and would run poorly. If it's even out one tooth,
it will be totally gutless until warm, then only very gutless. Did you
change or at least inspect the PCV?
Save your money, I dont' think it needs high octane gas. I prefer
gasohol from time to time for the sake of keeping injectors clean.
'Curly'
jim beam
Guest
Posts: n/a
usual suspects are, in no particular order, plugs, leads, distributor
cap, rotor, egr valve, pcv valve, timing, thermostat, oxygen sensor,
coolant level, tandem valve, vacuum pipes, dirty injectors, jumped
timing belt, ...
if you can be more specific with the tests you've performed to eliminate
any of the above, we can be more specific with advice.
Old Jul 27, 2005 | 10:30 AM
sonal83
Guest
Posts: n/a
Goodmorning,thank for hint but like to know what is EGR and where it's
located in engine? thank u.d.patel
andrew416
May 21, 2008 06:52 PM
sade001
Oct 15, 2005 09:40 PM
Dick
Jul 21, 2005 07:31 PM
isabelaneric
Jun 29, 2005 10:39 AM
classicred
May 4, 2005 11:16 AM
