How to get more air circulation under the hood?
Old May 2, 2008 | 06:22 PM
Sugarphreak's Avatar
Push My Button
I am looking for the most cost effective way to encourage more air circulation under the hood to lower temps a bit.
It feels like a heat wave every time I open the hood now that I have my new manifold installed and it isn't even the summer yet!
There are a few options I know of; hoods, under skid pans, air deflectors, grill inserts, supplement fans, ect.
Which option is going to provide the biggest bang for the buck
Old May 2, 2008 | 06:36 PM
Tofuman's Avatar
ditch the fog lights and put in custom ducting to the engine bay. upgrade the cooling system. hood scoop.
Old May 2, 2008 | 07:54 PM
Fitting's Avatar
Washers under the hood hinges to angle the hood and vent it in the back.
Run w/o a hood, joking
Old May 3, 2008 | 12:14 AM
SD_MR_FIT's Avatar
do the washer trick. i have 11 on each side.
well on each bolt heh.
Old May 3, 2008 | 12:47 AM
kelsodeez's Avatar
UNBANABLE
i got an idea from looking at my friends ferrari to get more air to the engine in any car. the ferrari had vents inside the wheel well in the rear (where the engine is) with like a small mesh screen over the inside of it. what if you drilled out a few holes and put some screen on the inside of it or went to the hardware store and got some vents to put on the inside of your wheel well.
Old May 3, 2008 | 11:27 AM
Push My Button
lol, great way to keep my engine clean too
All good suggestions, I have a feeling the best way is to use an after market hood w/ scoop in conjunction with the vented skid pan.
However I am shying away from hoods over the price and bolt on hood scoops mostly over the tackiness I also like my foggies!
I think I am going to look at either some custom ducting or ways to deflect air more efficiently to start.
Old May 3, 2008 | 11:34 AM
dank24's Avatar
Take out the grill.
Old May 5, 2008 | 07:20 PM
Push My Button
I removed a little black shoud from just above the fan yesterday, it opened up the grill to let more air in.... it just snapped off with 4 pins.
Old May 5, 2008 | 09:47 PM
ldweng's Avatar
Try a ceramic header insulation like Swain Tech or Jet-Hot.
Old May 5, 2008 | 09:59 PM
gmane's Avatar
Or you could buy the ARC racing part that does this exact samething i believe
Old May 5, 2008 | 11:02 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
the best way to have a ram air is from the bottom going up vs. venting hood or something of that sort.
Old May 5, 2008 | 11:09 PM
Push My Button
This sounds good, any chance you have some photo examples handy?
Old May 6, 2008 | 12:15 AM
03DSM-RSX's Avatar
sorry i dont.
it was a technical performance method with a bunch of physics involved in help explaining why it was better getting air to flow bottom to top.
also, why do u really need to be concerned with underhood temps? when the car is moving it does not get as hot vs. at a standstill. If u want to reduce radiating heat from the manifold, get it coated. This would be the better route of doing it.
I recommend swaintech.com. Best in the business imo, whether it be exhaust manifolds, intake manis, combustion chambers, etc etc. i've tried polydyn, jethot, and HPC. none compares to swaintech.
When i first installed the turbo, underhood temps were unbearable. i got the manifold, exhaust side, and downpipe coated with Polydyn/HPC/Jethot (all similar stuff to each other btw). It helped only a little. So i tried out swaintech. BAAM, underhood temps drastically decreased (a bit cooler than stock). I everything is so much cooler than it was before.
Old May 6, 2008 | 12:36 AM
solbrothers's Avatar
rake hood or get a vented hood.
Old May 6, 2008 | 10:59 AM
Push My Button
sorry i dont.
Since I have had everything installed even if I go for a quick drive after I pop the hood the amount of heat coming out is concerning me. It isn't even all that warm here yet.
I can't really afford to send off my header for coating, both from a cost side and a logistical side. I need my car for daily driving.
I am wondering if I can get away with using some header wrap
I also have some idea's on how to create an air ram from below. I will have a closer look this weekend to see how feesible it is.
Originally Posted by bryanback
You're suggesting speed holes. Those generally go in the hood to make the car go faster.
Sweet, speed holes!!
So much cost!! Plus I will loose my stealthy stock look that keeps the 5.0 off my back.
Old May 7, 2008 | 12:40 PM
Tofuman's Avatar
a header wrap or the swaintech will reduce engine bay temperature a lot.
Old May 16, 2008 | 03:47 PM
henryd1981's Avatar
I think that came from an episode of The Simpsons.
Old May 16, 2008 | 04:10 PM
Push My Button
Damn, I am out of time. This seems cheap and easy, will give it a try before I hit the course tommorow in +29 weather.... gulp
Old May 16, 2008 | 04:51 PM
kimo's Avatar
Drive without the hood
Old May 16, 2008 | 05:12 PM
Push My Button
Is it bad I have considered this
