91 Accord Cooling Fan Runs Slow?
Old Jul 31, 2005 | 02:46 AM
Todd K.
Guest
Posts: n/a
I think my radiator cooling cooling fan (passengers side) is running
way slow. The condenser fan (drivers side) seems to be really cranking
out the air.
Are these two fans supposed to run at about the same speed/airflow?
What other year Accords use the same fan? (so I can junk yard it)
Todd K.
Old Jul 31, 2005 | 06:45 PM
SoCalMike
Guest
Posts: n/a
Re: 91 Accord Cooling Fan Runs Slow?
> out the air.
should. id jumper the fan directly to the battery and see if it speeds
up. if it does, youve got flaky wiring or connections somewhere.
likely any 90-94 with air conditioning.
> Todd K.
Old Jul 31, 2005 | 07:30 PM
Professor
Guest
Posts: n/a
Both fans should run about the same speed. Check the ground on the slow
fan...
Professor
www.telstar-electronics.com
Old Aug 1, 2005 | 01:50 AM
Todd K.
Guest
Posts: n/a
Thanks for the tips. Its working now. Here's what I did:
Ran the diags from the service manual. While doing so, I noticed that
the fan would only run if I gave it a little spin. It still ran slow
though. So OK, bad motor. I took it out to try and rebuild the motor
(I did this succesfully on older Honda). Before I was to take the
motor apart, I hooked it up straight to battery just to make sure. It
ran great. Hooked it back up to connector. Ran the diags again.
Everything worked fine. I guess the jiggling to remove the fan freed
up some hung up brushes. I had a similar problem on the alternator
last fall. I removed a couple screws, jiggled the brush holder and
alternator has been fine since. A EE friend of mine says this is
common with small motors as the brushes wear down. They hang up and
the spring can't seat them properly on the commutator. A little jiggle
frees them up and they may run trouble free for a long time after that.
Todd K.
Old Aug 1, 2005 | 10:46 AM
Frank Boettcher
Guest
Posts: n/a
Do you happen to know where you can get replacement brushes for those
little fan motors? I just replaced a motor and when I cracked it open
the only thing wrong with it was the brushes were worn down so that
they could no longer make contact with the commutator.
>Todd K.
Old Aug 1, 2005 | 12:44 PM
Todd K.
Guest
Posts: n/a
I got mine at ACE hardware in those specialty hardware boxes.
Todd K.
Frank Boettcher
Guest
Posts: n/a
Thanks, I'll give them a try
>Todd K.
Old Aug 1, 2005 | 11:52 PM
SoCalMike
Guest
Posts: n/a
>>Todd K.
lowes, home depot, and NAPA also have specialty hardware boxes, in case
ACE doesnt pan out.
boltaction
Jul 11, 2018 10:52 AM
Mugen_Dom
May 13, 2006 10:18 PM
simondet
Oct 8, 2005 09:30 AM
Al Davis
May 15, 2005 07:30 PM
TeGGeR®
