What glue for door upholstry?
Old Aug 1, 2005 | 10:46 AM
Todd K.
Guest
Posts: n/a
The upholstry fabric on the inside of my doors ('91 Accord) is falling
down. I have tried 3M spray adhesive. It works for a couple of weeks
then breaks down. The problem, I think is the vinyl I'm trying to
stick the fabric too is very slick.
Todd K.
Frank Boettcher
Guest
Posts: n/a
Re: What glue for door upholstry?
I have the same problem with my 90 Accord. I've tried 3M 90, 3M 77,
Contact Cement. Nothing holds that stuff on.
The research I did indicated that the plastic panel may be what they
call Low E material. It is very difficult to get anything to bond to
it.
I'm going to try 3M hi-tack 76 next week end. 3M info indicates it
may be the best they have in the aresol cans that might work with a
Low E plastic. Will report if I have any luck. Of course you don't
know until a couple of weeks to a couple of months when it normally
starts to fall off again whether you have been successful.
I may also try to put a line of epoxy in the perimeter groove, see if
that helps.
Frank
>Todd K.
Old Aug 1, 2005 | 11:44 AM
motsco_ _
Guest
Posts: n/a
> Todd K.
When patching tires, they have to rough up the surface of the rubber
with a wire brush or sandpaper so the glue can stick to the 'scratches'.
It's the same with adhesives and plastic / vinyl. Use some sandpaper on
the smooth part, paint both surfaces lightly with contact cement and LET
DRY for a several minutes (instructions on can). Assemble. Jet it
straight, since it's going to be forever.
'Curly'
Old Aug 1, 2005 | 02:30 PM
Todd K.
Guest
Posts: n/a
Thanks, I'm anxiously awaiting your feedback.
Todd K.
Old Aug 1, 2005 | 03:43 PM
_karu_'s Avatar
hey....that trick with sandpaper seems to be quite promising..
i think i have to do the same thing with my civic..
SHOELAC3D
Oct 3, 2013 11:22 AM
BC
Aug 22, 2005 10:42 PM
Frank Boettcher
Aug 9, 2005 10:48 AM
Handle-less
Jul 1, 2005 08:56 AM
Randolph
May 4, 2005 11:16 AM
