Frozen and/or broken brake bleed valves.
Old Aug 9, 2005 | 04:30 PM
r2000swler@hotmail.com
Guest
Posts: n/a
Anyone have any advice on how to free frozen (rusted)
bleed valves.
And if they brake, what is the easist, and cheapest
fix. I could always replace the caliper/wheel cylinder,
but that gets pricy, and 99 times out of a 100 you will
have to replace the hard line.
A coworkers daughter faces this problem. 19 year old
starting college in 3 weeks and her money situation
is tight.
The brakes work, no squeal, but the peddle is mushy.
She hasn't had any brake work done in the 3 years she
has owned the car.
Yea I know she reaps what she sows, but she is a nice,
and otherwise responsable kid. I am up to changing the
fluid and bleeding the brakes, but the valves scare me.
Terry
Old Aug 9, 2005 | 06:30 PM
Robert Mozeleski
Guest
Posts: n/a
Re: Frozen and/or broken brake bleed valves.
Thought i would have that problem too but the bleeders cracked loose on a 17
year old Honda.
<r2000swler@hotmail.com> wrote in message
news:1123616492.477753.131430@z14g2000cwz.googlegr oups.com...
> bleed valves.
> is tight.
> has owned the car.
> Terry
Bruce
Guest
Posts: n/a
Try some PB plaster or other such penetrating lubricant. Spray it on
and let it sit for half an hour, try to loosen it, repeat if necessary.
I used PB blaster to get off the lower exhaust manifold bolts on a 15
year-old toyota pickup... if it'll do that it should get your bleeder
valves loose.
Old Aug 9, 2005 | 07:30 PM
SoCalMike
Guest
Posts: n/a
gentle tapping on it to loosen the rust, then remove. if it breaks? id
get an ezy-out tap and some new bleeder screws. its kinda a
reverse-thread drillbit thingie that bites the metal and helps it unscrew.
Bulldozer27
Jun 12, 2023 12:50 PM
robs
Mar 3, 2018 07:54 PM
Mister Coffee
Aug 28, 2015 12:56 AM
Dean
Jul 20, 2005 01:35 PM
subhamoy@gmail.com
Jun 18, 2005 10:17 AM
