blinkers wont work!! i need help!
Old May 20, 2008 | 06:40 PM
kelsodeez's Avatar
UNBANABLE
so i took out my gauges and unplugged my hazzard switch and drove my car down to my house. the next day (today) i put the gauges back in. i had a check engine light but i disconnected the battery and it went away. now my blinkers dont work. my buddy said its probably because i disconnected the hazzard switch. so i reconnected it, my blinkers still dont work. i disconnected my battery again and tried it but they just are dead! they blink when i hit the alarm but not when i switch the turn indicator arm on the steering column. how can i fix this?? please help!
Old May 20, 2008 | 06:46 PM
koolkevin1107's Avatar
hmm that's strange. Never heard of that happening. I know that the turn signals have 2 go through the hazard switch to operate so thats why the turn signals didnt work when u had ur hazard disconnected. the only way i would think 2 fix this is to disconnect ur battery, disconnect the gauges and the hazard switch completely. Turn on ur headlights to drain any existing power left in the circuitry. Then reconnect the hazard and the gauges, making sure u plug all of em back in. Then reconnect the battery and give it a try.
Old May 20, 2008 | 07:34 PM
kelsodeez's Avatar
UNBANABLE
thanks for the suggestion kevin. i tried that and they still arent working. i dont get it. my fuses are fine, and everything is plugged in except the headunit and the hvac. ugh!!
Old May 20, 2008 | 08:05 PM
kelsodeez's Avatar
UNBANABLE
grrrr. i am THIS close to bringing it to someone. its a mystery.
Old May 20, 2008 | 08:54 PM
Whitehybrid's Avatar
did u check the blinker fluid level?
may be low...
Old May 20, 2008 | 08:56 PM
kelsodeez's Avatar
UNBANABLE
har har har
but thanks for the bump. i need info on this.
Old May 20, 2008 | 08:58 PM
manxman's Avatar
Kelsey-
Watch for incoming lead balloons. wish I could help, but---
Old May 20, 2008 | 09:00 PM
har har har
lol no prob
did u check all of ur wiring? maybe a connector to your blinker switch isnt hooked up?...
do your wipers work?
Old May 20, 2008 | 09:01 PM
kelsodeez's Avatar
UNBANABLE
yea im just going to have to do some electrical testing tomorrow. im hoping its a simple fix. i really dont want to tear apart my wiring harness.
Old May 20, 2008 | 09:04 PM
kelsodeez's Avatar
UNBANABLE
Originally Posted by Whitehybrid
lol no prob
yes. everything works fine except for the hazard switch and the blinkers. i checked all the connections and all plugs are ok. im thinking its either a bad wire or i somehow damaged the hazard switch housing because i know that in hondas, the blinkers wont work if the hazard switch is unplugged.
Old May 21, 2008 | 01:22 PM
99dx's Avatar
Ya I had this problem on my civic. When I installed an aftermarket stereo the hazard plug came loose and I lost my turn signals and hazard lights. If I pushed it really tight together I could get it to work, finally bought a new one and discovered a clip on one side had snapped off. I probably could have fixed it with just some electrical tape.
Old May 21, 2008 | 02:44 PM
kelsodeez's Avatar
UNBANABLE
im just wondering if there is a "safe mode" that the ecu goes through to protect the circuitry from shorting out. if i have to take my car to honda to get plugged into the computer and reset, i am going to be pissed!
Old May 21, 2008 | 02:50 PM
GD3-Fit's Avatar
I <3 SPOON
yikes sorry i can't help you out on this one man
hope everything works out
keep us updated
Old May 21, 2008 | 06:29 PM
Sloto200's Avatar
I'm betting one of the connectors you disconnected around the gauges has a loose pin. It probably isnt making contact so your hazards and blinkers arent working. I'm sure the blinkers get their power from a different source when you hit the keyless entry. Look over your connectors real good, make sure you dont have a loose or broken pin. Or like said above... you could try this...
Old May 21, 2008 | 06:51 PM
kelsodeez's Avatar
UNBANABLE
so, i was messing with the hazard switch and i guess when i took it out, the plastic casing on the inside came apart. it snapped back together and voila! my blinkers work!! yay. i was stressing bad about this. i am thanking my lucky stars that it was a simple fix.
oh and i topped off my blinker fluid
Old May 21, 2008 | 06:58 PM
Sloto200's Avatar
Thumbs up
glad you found it!
phenoyz
Aug 8, 2013 05:29 AM
StormSurfer
Jul 25, 2011 02:05 PM
Lyon[Nightroad]
May 2, 2010 02:12 PM
toonie
Oct 30, 2009 06:43 AM
FDaviDH2
Sep 9, 2005 12:30 PM
