Swapping out brake bleeder screws
Old Aug 11, 2005 | 04:32 PM
MAT
Guest
Posts: n/a
Hi All,
I finally got speedbleeders for my Si of which I plan on installing with
fresh brake fluid this weekend. My question is can I replace each screw and
bleed it one corner at a time in one step or do I need to replace all 4
bleed screws and go back and bleed them again. I'm wondering if totally
removing/replacing the 2nd screw in a single L/R channel blows the bleed for
the 1st in the same channel. Hopefully this makes sense. Thanks!
Old Aug 11, 2005 | 07:08 PM
twfsa
Guest
Posts: n/a
Re: Swapping out brake bleeder screws
Fill the master cylinder, start at the wheel furthest from the master
cylinder, replace bleeders one at a time, then go back and bleed furthest
from the master cylinder, working your way to the master cylinder,keeping an
eye on the fluid level, this is how I would do it.
Tom
"MAT" <marcoat*RM_@SPAM_*hotmail.com> wrote in message
news:2ZWdnRkFaMyLP2bfRVn-rw@comcast.com...
> Hi All,
> and bleed it one corner at a time in one step or do I need to replace all
> 4 bleed screws and go back and bleed them again. I'm wondering if totally
> for the 1st in the same channel. Hopefully this makes sense. Thanks!
Old Aug 11, 2005 | 09:30 PM
Bruce
Guest
Posts: n/a
right on...
I concur.
Bulldozer27
Jun 12, 2023 12:50 PM
robs
Mar 3, 2018 07:54 PM
sailorman2439
Oct 2, 2016 04:43 PM
sailorman2439
Aug 25, 2016 12:04 AM
ShotgunSi
Apr 22, 2014 07:33 AM
