Bleeding Brakes
Old Apr 21, 2014 | 11:52 AM
ShotgunSi's Avatar
Bleeding Brakes
I have a 2009 Fit Sport with manual transmission.
I bled my brakes over the weekend and only used about 1.5 bottles of Honda DOT3 brake fluid. The bottles were 12oz in size. I was told by the Honda parts guy I would need at least 3 bottles to bleed the system but perhaps he just wanted to sell me more brake fluid. I also bled out the master cylinder and the clutch / slave cylinder as well.
My question is, did I fully bleed the system if I only used about 18oz of brake fluid?
The brakes are fine after the flush and the brake pedal does feel a bit less hard compared to before.
Old Apr 21, 2014 | 01:43 PM
kobudo's Avatar
You may have a bit of air left in the system. The brale pedal should feel very hard with the car running.
Old Apr 22, 2014 | 07:33 AM
Carbuff2's Avatar
Did you bleed until the exiting fluid became noticeably lighter in color? If so, you 'aced' it.
I usually use two bottles of Honda brake fluid to replace. The clutch system requires about 3/4 bottle.
QuanticBeat
May 27, 2024 10:19 AM
Bulldozer27
Jun 12, 2023 12:50 PM
robs
Mar 3, 2018 07:54 PM
sailorman2439
Oct 2, 2016 04:43 PM
sailorman2439
Aug 25, 2016 12:04 AM
