headers=bad mpg????
Old May 30, 2008 | 01:40 PM
pr0jectezek1el's Avatar
headers=bad mpg????
hello
i just bought some megan header for my 08 fit. i want to install them this weekend but was wondering with the header install would give me bad gas mileage with stock intake and exhaust system?
thanks
Le
Old May 30, 2008 | 03:20 PM
Sugarphreak's Avatar
Push My Button
I have the T1R headers, practically no change in mileage
Old May 30, 2008 | 03:36 PM
Evotech8's Avatar
A header alone is not going to adversely affect your gas mileage.
It should actually improve your gas mileage slightly due to better exhaust efficiency. The stock header is a very restrictive design.
I noticed I don't need to press the gas peddle as much as before to accelerate up to the same speed, thus saving gas.
Old May 30, 2008 | 03:44 PM
FITrunner's Avatar
Mpg shouldn't be affected much out of the box. However propensity to drive faster might go up, which will cause your mpg to go down.
Old May 30, 2008 | 04:04 PM
Rod2Rice's Avatar
It can affect it a little. Not sure the design on the headers for the Fit, but most add to the high and, and can reduce low end torque, which could cause a slight loss down low.
Old May 30, 2008 | 05:28 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I have a few mods (no header yet) but my MPG is still plenty fine.
36ish MPG city per tank.
Old May 31, 2008 | 01:45 AM
isthata_scion's Avatar
any carb legal headers?
Old May 31, 2008 | 02:28 AM
SPON FIT's Avatar
header doesn't mean bad mpg.right foot means bad mpg
nope
Old May 31, 2008 | 07:45 AM
Rod2Rice's Avatar
nope
true but if you lose some low end torque, you are gonna be on the pedal more to get going which would = less mpg. Since these motors arent putting out much to begin with, and loss I would imagine would barely be noticeable.
Old May 31, 2008 | 07:55 PM
08FitSport's Avatar
Originally Posted by pr0jectezek1el
hello
thanks
Le
When you first put it on the foot becomes heavier. But, ordinary driving it should get better less throttle, more power on tap.
Weapon R + 2 mpg.
Old May 31, 2008 | 09:04 PM
^ sweet thanks
Le
Old May 31, 2008 | 10:56 PM
m-man@sbcglobal.net's Avatar
from looking at aftermarket headers for the fit, they seem to look amost idenitical to the stock "manifold" which has made me hesitate from buying one,
do you notice a diffence since installing?
also i think DC is making a CARB legal one, its expensive though
Old Jun 1, 2008 | 04:52 AM
thanks for all the replies
kinda off topic but i am having trouble with the bolts that hold the header to the engine. can anyone suggest anything to help me get the bolts off?
thanks
Le
Old Jun 1, 2008 | 12:51 PM
Arisenfury's Avatar
Weapon*R headers add torque down low, best mod I ever did. Also there was no drop in MPG with the headers installed compared to stock headers. If anything a year later after adding i/h/e and lightweight wheels my MPG has gone up 3-4 from what I was getting last May with the car completely stock.
Old Jun 1, 2008 | 01:43 PM
Evotech8's Avatar
thanks
Le
I found it easier to remove the 14mm header bolts/nuts using a deep socket (6-sided) and one of those 'tilting/swivel' head type socket wrenches with the longest arm 10"-12" for more leverage. All the bolts/nuts can be accessed from the top.
Yup, those damn header bolt/nuts are hard to break loose.
Blackbeard
Mar 9, 2015 10:44 AM
oshiri
Apr 26, 2011 10:33 PM
setter11
May 4, 2009 01:43 PM
modfit669
Sep 25, 2008 08:15 PM
08FitSport
Mar 28, 2008 09:54 AM
