Thermo Exhaust Wrap
Old Jun 5, 2008 | 02:27 PM
pr0jectezek1el's Avatar
Thermo Exhaust Wrap
Hi
i just installed my megan racing header. i was driving around and came back home to check if there was any leaks and when i open the hood there was alot more heat from the headers. My question is had anyone ever used thermo exhaust wrap on there header before and does it make big difference in reducing the temperature under the hood?
this is the product i want to get
THERMO-TEC EXHAUST WRAP: 1" X 50' (BLACK)-Options Auto Salon
thanks
Le
Old Jun 5, 2008 | 02:30 PM
Fit_to_be_tied's Avatar
it reduces heat, but the heating and cooling of the header makes moisture that gets trapped and rots the header. i went through many racing back in the day, however it is possible the the new coated headers may survive.
Old Jun 5, 2008 | 03:46 PM
yeamans17's Avatar
Not with the coating on a Megan header, the coating on those headers is crap they're turn brown and start to rust within a year.
Old Jun 5, 2008 | 05:00 PM
Rod2Rice's Avatar
Dont use that stuff, as above it will cause more problems than its worth. Not sure what kind of coating, if any, was on your header, but you'd be much better off with a Jet Hot or some other ceramic coating.
Old Jun 5, 2008 | 05:03 PM
JDMchris.com's Avatar
I run THIS
Ive had mine about 2 years now and that hasnt happened.
Old Jun 5, 2008 | 06:00 PM
yeamans17's Avatar
Which coating did you get? The SS coating on them is shit. But it may also be because you live in Cali
Old Jun 5, 2008 | 06:20 PM
I run THIS
might be? might also be because I had a prototype version?
Old Jun 6, 2008 | 05:28 AM
so should i get it or not? The reason why i am getting the thermo wrap because i was kinda scared with the extra heat the hoses near the header would get damage
thanks
Old Jun 6, 2008 | 06:02 AM
ezduzit's Avatar
You can use some stainless steel zip ties to put the stock heat shield back on over your header.
That's what I did.
ez
Old Jun 6, 2008 | 03:06 PM
thats sounds pretty cool. can you take some pictures?
thanks
Le
Old Jun 6, 2008 | 04:11 PM
ezduzit's Avatar
thanks
Le
I'll try to take some this weekend. Posting them here, however, has been kind of a crap shoot for me. Sometimes I can and sometimes it ain't workin'.
ez
MISTERHONDA
Feb 20, 2016 10:18 AM
Cordizzle4life
May 27, 2014 11:51 PM
im the fit
Apr 6, 2009 10:26 AM
jaebee
Aug 9, 2008 05:30 PM
