94 Accord A/C not working
Old Aug 21, 2005 | 01:48 PM
cmilner2
Guest
Posts: n/a
My 94 Accord A/C will not work. The compressor kicks on, and I've checked
the freeon (spelling?) level and it's high. Any suggestions for things to
check other than the compressor and freeon?
Thanks
Old Aug 24, 2005 | 01:42 AM
James Watson
Guest
Posts: n/a
Re: 94 Accord A/C not working
"cmilner2" <cmilner@hotmail.com> wrote in message
news:c035589f2b296b6252857a0daed46304@localhost.ta lkaboutautos.com...
> Thanks
Checking that the compressor clutch is spinning and freon is present a good
first step. Without knowing more, my guess is that your compressor is no
longer "compressing" properly - you should have a pressure difference
between the 'High' and 'Low' side of the system. Take it to a Tune Up shop
that handles A/C and have it checked. You should be able to find a shop
that will check the pressure for a "special price" of $20-30. My guess is
that the pressure differential will turn out to be virtually zero. If that
is the case, expect to have to replace the compressor, evaporator and
condenser... Mechanics charge $1200+ easy for parts and labor.
'Curly Q. Links'
Guest
Posts: n/a
> Thanks
Freon pressure HIGH is just as bad as LOW . . It will shut the system
OFF. There's a safety switch for BOTH conditions.
'Curly'
Old Aug 25, 2005 | 12:33 AM
Randolph
Guest
Posts: n/a
> > Thanks
> 'Curly'
And in case you don't find two switches, Honda often uses a single
switch that will trip at both too high and too low pressure.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
gahris
May 14, 2017 04:51 PM
Sjensen9
Aug 8, 2015 11:13 AM
fmstrohl
Jul 5, 2006 04:51 AM
Aw
Oct 13, 2005 11:31 PM
Frank Boettcher
Jun 18, 2005 10:17 AM
