HELP ! Need '86 Prelude cooling system info
Old Aug 23, 2005 | 10:36 PM
preludeprob
Guest
Posts: n/a
I have an '86 Honda Prelude 2.0 Si, it has developed a coolant leak. Coming
out of the rear of the water pump housing is a long steel tube that runs
under the intake / injectors. I need to remove this tube and replace it
but I can't figure out how to get it out. Does it just pull out, is it
threaded, do I have to remove the intake to get it out. I'm a motorcycle
mechanic and good skills, but this one's got me puzzled. HELP! HELP!
HELP! Many Thanks!!! Matt
Old Aug 24, 2005 | 01:42 AM
TeGGeR®
Guest
Posts: n/a
Re: HELP ! Need '86 Prelude cooling system info
"preludeprob" <berr4888@nospam.bellsouth.net> wrote in
news:82876c030baddfc4c2bdfe6381c88b5b@localhost.ta lkaboutautos.com:
> Coming out of the rear of the water pump housing is a long steel tube
> that runs under the intake / injectors. I need to remove this tube and
> replace it but I can't figure out how to get it out. Does it just pull
> out, is it threaded, do I have to remove the intake to get it out. I'm
> a motorcycle mechanic and good skills, but this one's got me puzzled.
> HELP! HELP! HELP! Many Thanks!!! Matt
Just pulls out. You just need to remove the thermostat housing, not the
intake. The housing bolts face the firewall, as I recall. They're not the
same bolts you remove to replace the thermostat. Space is tight, and you
may find better access from underneath for the water pump side of things.
It will be pretty rusty and gungy, so you'll need to do lots of cleanup and
light scraping of the housings to make sure the new tube (and its O-rings)
seals properly.
TeGGeR®
www.tegger.com/hondafaq/
preludeprob
Guest
Posts: n/a
Thank you so much for your help! I can't thank you enough ! ! Matt
Old Aug 24, 2005 | 05:30 AM
preludeprob
Guest
Posts: n/a
Is this a dealer only part?
Old Aug 24, 2005 | 09:38 AM
TeGGeR®
Guest
Posts: n/a
news:23e07dce62189be1a6500a8737194d40@localhost.ta lkaboutautos.com:
Very likely. I can't see it costing much, though.
You'd be very wise to make absolutely sure it's coming from the tube before
buying a new one.
TeGGeR®
Old Aug 24, 2005 | 02:31 PM
preludeprob
Guest
Posts: n/a
i'm positive that it's coming from the tube, thanks again. Matt
Mynodha
Dec 11, 2013 08:41 PM
1990hondahf
Oct 23, 2009 12:22 AM
Kuturagi
Mar 8, 2008 02:30 PM
jezzy's jazz
Feb 20, 2007 05:43 PM
