alternator needed
Old Aug 26, 2005 | 06:37 PM
shakenbake
Guest
Posts: n/a
alternator needed
I need specific info on how to locate the exact alternator replacement for
my 84 model prelude 1.8L engine after atempting to replace it with an auto
zone reman only to discover the plugins were not the same the original has
only 2 while most if not all i've seen so far on the net and local parts
store are equipped with 3 prongs which after installation will not charge.
any info on this topic will be greatly appreciated
Old Aug 26, 2005 | 07:33 PM
T L via CarKB.com
Guest
Posts: n/a
Re: alternator needed
I got one off of ebay for $40 US, for an 87 prelude 1.8L.
Whats wrong with yours? Pretty easy and inexpensive to replace the brushes
and bearings. After I bought that one off of ebay, I rebuilt the old one for
about $8.
Best thing to do is put your old one side by side with the new one, make sure
the plugs and mounting points are the same. Some are interchangeable, some
aren't.
Your 84 has an external regulator, just like the 87. I'm in Winnipeg, if you
wanna buy this one offa me let me know.
t
Message posted via CarKB.com
http://www.carkb.com/Uwe/Forums.aspx...-cars/200508/1
Old Aug 26, 2005 | 09:52 PM
Elle
Guest
Posts: n/a
Like the other poster said, you can try Ebay or doing your own rebuild.
Also consider a remanufactured alternator from Majestic online OEM honda
parts. It's $112 + s/h there.
http://www.hondaautomotiveparts.com/...p?catcgry4=ALT
ERNATORS&catcgry5=83-87%20PRELUDE%20DX
Old Aug 26, 2005 | 10:31 PM
shakenbake
Guest
Posts: n/a
T L the problem is i returned the core to a local auto parts store when i
purchased the reman. and it was shipped out or so they say before i
returned for it and a refund. I don't have anything to work with unable to
locate any salvage part how much for the one off yours or which units will
interchange
Old Aug 27, 2005 | 01:31 AM
T L via CarKB.com
Guest
Posts: n/a
Hey shake,
Where are you located? I gotta put it back together and test it, but I'm
sure its good to go. It cost me about $40 canadian by the time I got it here
and everything. Only thing that was not right about it was that the thread
for the pulley bolt was a little messed up. I will see if it is fixable, and
if so, would you want it?
According to the websites I have checked, it is interchangeable... but you
may want to do some research yourself.
t
>interchange
T L via CarKB.com
Guest
Posts: n/a
PS, the way I checked to see if they are interchangeable was to go to
www.maximumautoparts.com. I then checked the part number of the alternator
for an 84, and compared it to the 87. They were the same...
t
T L wrote:
>Hey shake,
>t
>>interchange
shakenbake
Guest
Posts: n/a
ya T I certainly would be interested in purchasing the alternator would
quote me a price i'am located in Pine Bluff Arkansas
Sublime01
Apr 27, 2019 12:51 PM
Kevin Evans
Dec 13, 2018 11:01 PM
craigquakertown
Jul 3, 2017 02:58 PM
deevergote
Dec 4, 2015 07:52 AM
disallow
May 4, 2005 11:16 AM
