Looking to get some wheels
Old Jun 22, 2008 | 11:01 AM
paulw86's Avatar
Cheapest set of Kosei K1 TS 17x7 with or without tires, used or new
Any ideas?
Thanks
Old Jun 22, 2008 | 11:10 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
First off, why 17's? Id suggest some 15's or 16's. With 17's you may run into rubbing problems. Lowered or not.
17in tires arent that cheap, not to mention youll need a odd ball size to keep rubbing down.
Mike put these up a little while ago. Seems he still has them.
Not sure if he'd want to ship to BC? Wouldnt hurt to ask.
https://www.fitfreak.net/forums/sale...k-1-white.html
Old Jun 22, 2008 | 11:25 AM
paulw86's Avatar
thanks for letting me know about Mike's sale. I did see his thread but I was looking for the TS model which looks and weights different.
As for why I'm going for 17s...
for looks
for possibility of adding a big brake kit after turboing
and for 4.4lbs/rim more than the lightest readily avaliable 15x7 Enkei RPF01, I'm not really losing tooo much in the performance department, no? I mean I'll probably track the car max like couple times a year.
Old Jun 22, 2008 | 01:53 PM
Posts in the NUUDE
I think the people running big brake kits have 16's. I honestly wouldnt suggest 17's if you want any kind of performance. Turbo or not.
Old Jun 26, 2008 | 09:49 PM
mahout's Avatar
[quote=paulw86;345459]Cheapest set of Kosei K1 TS 17x7 with or without tires, used or new
Three of the non-lowered Fits we have equipped with aftermarket wheels have been 17x7/42mm offset with 205/40x17 tires and they indeed look the best of any of the 15 16, or 17 " tire/wheel combinations so I agree with your choice. Yes the ride will be a little stiffer than 7x16/205/45x16 wheel/tire combination of similar diameter but entirely acceptable.
If you plan to lower you will need to have wheels 45 mm offset rather than 42mm.
I recommend two sources for those 17x7/205/40x17 combinations:
Edge Racing.com or DiscountTireDirect.com. Both offer a good selection and prices and offer mounting and balancing free of charge. DiscountTire also offers free shipping. I don't think either offers Kosei but check with them. And yes, you will see a little loss from the combination on performance. Mine also has rear discs and Hawk pads that brake as well as anything on track.
Good luck.
Old Jun 27, 2008 | 12:06 AM
TOOL's Avatar
+1
Id say 15's, at the biggest 16's.
Tyler
Old Jun 27, 2008 | 12:14 AM
SD_MR_FIT's Avatar
well some big brake kits recommend running 17"s
uh....yeah 205/40/17 isnt that odd ball size is it?
Old Jun 27, 2008 | 07:39 AM
mahout's Avatar
uh....yeah 205/40/17 isnt that odd ball size is it?[/quote]
common as dirt, and almost as cheap.
Old Jun 27, 2008 | 09:32 AM
Illusive's Avatar
Very common tire size. Was running that on my Enkei's.
hexinverter
17
Mar 28, 2014 10:01 AM
Sooner97
Jan 24, 2012 12:20 AM
Ninkumpoop
Oct 1, 2011 05:27 AM
Opti
Jul 3, 2008 07:23 PM
07TaffetaFit
Texas Community
Sep 20, 2007 04:15 PM
