Check engine light won't shut off
Old Sep 2, 2005 | 08:30 PM
hisame2332
Guest
Posts: n/a
Please help...
I have a 1998 honda prelude. My check engine light has been on for 8
months... The mechanic says it's the O2 sensor (before catalytic
converter). I've replaced it with an OEM and unplug my battery to reset
the computer, but the light comes on the next day (happens everytime).
Does anyone know what's wrong or what I should do????
thanx in advance
TeGGeR®
Guest
Posts: n/a
Re: Check engine light won't shut off
"hisame2332" <hisame2332@yahoo.com> wrote in
news:5741bc471de8f6980d9a17b8cf8870a1@localhost.ta lkaboutautos.com:
> Please help...
> thanx in advance
Might be a totally different problem. What you're doing is not smart, and
you could cause further (very expensive) damage by ignoring the light.
If you're in the US, take it to AutoZone and get the code read for free.
Report back here.
TeGGeR®
www.tegger.com/hondafaq/
AZ Nomad
Guest
Posts: n/a
On Fri, 02 Sep 2005 19:25:34 -0400, hisame2332 <hisame2332@yahoo.com> wrote:
>Please help...
> thanx in advance
And you assume that because the O2 sensor was replaced that it can't possibly
be at fault? Silly you! It could be a defective part or it could have been
installed incorrectly. Why, pray tell, haven't you brought it back to the
mechanic?
If you bought a tire and it was flat the next day, would you spend the next
week driving on the flat tire and discussing it on usenet instead of just
taking the damn thing back to where you bought it?
hisame2332
Guest
Posts: n/a
Hi,
I've taken it to an automotive shop... and they've hooked it up to
their computer... the mechanic said that he didn't fine a code so he
doesn't know what the problem is so all he could do is reset the code...
however, the light came back on later that day... he said that I needed to
find a shop that is capable of running a complete diagnostic... does
AutoZone have this capability???
thanx again,
jim beam
Guest
Posts: n/a
hisame2332 wrote:
> Hi,
> thanx again,
if the light's coming on but the tech is not getting a code, it's one of
3 problems:
1. your tech doesn't know what they're doing.
2. there is something wrong with your ecu.
3. you're imagining it.
let's assume that 3 is not the case, and that 2 is most unlikely. that
leaves you the option of finding a different tech that is competent -
the ecu does /not/ show the light unless it's registered a fault code,
so the code /has/ to be stored. consider a dealer if this really is a
persistent issue.
Old Sep 2, 2005 | 09:32 PM
hisame2332
Guest
Posts: n/a
Hi,
That's true "aznomad"... I replaced the O2 sensor at one shop and the
mechanic cut off the light... 3 days later, got it diagnose at another
when it came back on... the second shop said that they could not find
anything wrong but they can cut the light off none the less... however, it
came on again and the second shop said that I never to get a "complete"
diagnostic from an $8000 machine... what would you guys recommand???
thanx
AZ Nomad
Guest
Posts: n/a
On Fri, 02 Sep 2005 20:30:10 -0400, hisame2332 <hisame2332@yahoo.com> wrote:
>Hi,
If that mechanic needs an $8000 machine to replace the skills of a 100IQ
mechanic with 2 years experience, he should be fired.
The light won't come on without there being codes to report. Unless the
computer itself is fried which is very unlikely.
If the second shop can't figure out how to read out the codes, then you've
somehow managed to find two incompetant shops.
Maybe the third one will be the charm.
As another poster mentioned, if you live in North America, find an autozone and
have them read out the codes for you.
TeGGeR®
Guest
Posts: n/a
news:04194af6ec5ab32932d64e5dca0d8598@localhost.ta lkaboutautos.com:
> Hi,
This means the code is probably a Honda "enhanced" code (P1, P2, P3, etc.)
and his reader won't see it.
You need to find a mechanic with a reader that will display Honda enhanced
codes.
> so he
> code... however, the light came back on later that day... he said that
> I needed to find a shop that is capable of running a complete
> diagnostic
Not quite, you just need a shop that has spent $600 for a REAL code reader.
> ... does AutoZone have this capability???
Yup. But not for free if you're in California.
TeGGeR®
hisame2332
Guest
Posts: n/a
Hi,
Ok... I'll do that... thank you so much for your help.
thanx again...
Old Sep 3, 2005 | 01:30 AM
SoCalMike
Guest
Posts: n/a
why is california so "speshul"?
i ended up spending $99 on an actron code reader.
Old Sep 4, 2005 | 01:30 AM
do_not_spam_me@my-deja.com
Guest
Posts: n/a
hisame2332 wrote:
> I replaced the O2 sensor at one shop and the mechanic
> cut off the light... 3 days later, got it diagnosed at
> another when it came back on... the second shop said
> that they could not find anything wrong but they can
> cut the light off none the less... however, it came
> on again and the second shop said that I can never to
> get a "complete" diagnostic from an $8000 machine...
Mechanics who can't diagnose a problem when there's a glowing Check
Engine light are absolutely incompetent, and even with a $200 machine
they should be able to narrow it down considerably by interpreting all
the sensor readings while the engine runs.
Can't even newer Hondas blink out a basic set of diagnostic codes
without the use of any equipment? You may want to check Mitchell and
factory manuals at a library for this and other information. There are
probably 200-500 pages of diagnostic tables for the fuel/emissions
system alone, and almost all component tests can be performed with a
cheap volt/ohm meter
Guest
Posts: n/a
Old Sep 21, 2005 | 07:30 PM
NiteOwl
Guest
Posts: n/a
Did you check or replace the gas cap? One that is not seating properly can
cause the check engine light to come on!
<do_not_spam_me@my-deja.com> wrote in message
news:1125811052.615380.209820@o13g2000cwo.googlegr oups.com...
Stacie Kahns
Sep 28, 2017 10:46 AM
TheDirtyBaby
Oct 21, 2010 11:18 AM
paulfit
May 14, 2010 02:02 PM
hondafitblue
Jun 9, 2009 06:35 PM
Velikimrav
Canada Fit Forums & Clubs
Apr 12, 2007 12:57 PM
