Do i have a dead battery?
Old Jul 5, 2008 | 04:30 PM
agent_paul's Avatar
Hiya guys, just a quick question.
i tried to start the car today but it would start (just made some really bad buzzing noise). every time i press on the breaks the dash lights blink. also the windows roll up and down slow.
so what do you guys think? dead battery?
Old Jul 6, 2008 | 08:29 AM
Carbuff2's Avatar
Certainly a weak battery, at least.
Have you checked the battery connections for corrosion and tightness?
If the battery is more than 4 years old, I'd just replace it. A lot of weird stuff happens to modern electronic-controlled cars when the batteries get weak...
Old Jul 6, 2008 | 08:38 AM
agent_paul's Avatar
ok cool ill change the battery as soon as i can, wiredest thing is that the battery indicator says the charge is ok...
Old Jul 6, 2008 | 02:52 PM
Fit_to_be_tied's Avatar
the indicator, or green eye, only shows one cell and it shows voltage not amperage so it is only a gimmick not a diagnostic tool
Old Aug 1, 2008 | 08:54 PM
caloyski5's Avatar
also replaced my battery recently. when the ignition switch was on, lights on my dash randomly flashed like crazy. frickin scary! the OEM battery from thai made jazz here in the PI sucks. gave out in 11 months
Old Sep 14, 2008 | 03:05 PM
smatts's Avatar
Honda Fit Forums Moderator
I'm having battery issues, and the indicator says its fine as well. I'm going to get it replaced this week.
I know it's a battery issue because a booster pack gets the car started every time.
Old Oct 5, 2008 | 03:39 AM
marz's Avatar
Thumbs up
had a battery problem took it to norm reeves honda told em i keep needing a jump so they checked it for free and gave me a copy of the slip showing it was a bad battery also honda gives like a five year warranty on there battery unlimited miles but anyway they had no fit battery in stock so i called around and the next day took the car and slip to downey honda world they changed it with no problem also washed the car for free
downey honda world
Old Oct 5, 2008 | 08:35 PM
willmax11's Avatar
Whenever I needed a new batt. for my '82 Celebrity I did not buy the book
rec. batt. but the biggest in the 72 series and bent the tray so it would fit. (Long cold winters).
Anybody measure how large, dimension wise, will go in a Fit tray?
pzriddle
Jan 23, 2015 06:31 PM
john21031
Nov 21, 2013 12:03 AM
hogwylde
May 27, 2013 06:18 PM
Remco
May 4, 2005 11:16 AM
Remco
