T1R rear disc conversion package!
Old Jul 11, 2008 | 10:03 PM
RubyQQ1211's Avatar
Disclaimer: Do at your own risk! etc.............
The installation guide from T1R is a great. Just adding something else that you might want to know!
1) Jack up the car, make sure it's stable, take out the wheel and the drum.
2) I used a flathead screwdriver and hammered the hub cap out.
3) Then I found out I don't have a tool for this and went to buy a 32mm impact socket.
4) Take out those four bolts and take out the rest of the drum kit.
5) Also remove the brake hose and the sensor. BE VERY CAREFUL OF THE ALLEN BOLT, it's very tight and I stripped one side.
6) Install new caliper bracket, put those four bolts and the allen bolt back.
7) Put the T1R ring into the hub and install the hub on the new bracket and disc.
8) Take the brake pad holder out from the caliper and install it first, use 2 of the wheel nut to hold down the disc
9) The caliper piston of mine stick out a little, makes it hard to install, you can push it back by turning the piston clockwise.
10) Remove center consle, and the old E brake component.
11) Install new E brake cable, this is very time consuming, and the rubber seal is very big. I cut it out first to make the installation easier and then make it smaller, so it will fit better.
12) I took out all of the new E brake cable brackets because I don't see how they fit on the original spot. I just zip tie the cable together.
13) Install new cable on the caliper and install the new brake hoses.
14) And after 8hrs, including buying tools and taking care of the stripped bolt. I STILL NEED SOMEONE TO HELP ME PUMP THE BRAKE WHILE I BLEED ><;
Old Jul 11, 2008 | 10:24 PM
dewthedew's Avatar
pics of the kit?
Old Jul 17, 2008 | 07:50 PM
xorbe's Avatar
ooh pics please
Old Aug 28, 2008 | 07:13 AM
RubyQQ1211's Avatar
Just finished DIY
Old Aug 28, 2008 | 07:30 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
wow looks great
but i want more pics of the yellow!!!
Old Aug 28, 2008 | 11:13 AM
aliencowboy's Avatar
Bleeding the breaks!
Try this:
Get a old soda bottle, Clear if possible, put about 1 in of break fluid in the bottle, get a piece of tubing (about 12-24 in, clear if possible) that will fit tight on the bleeder screw and put the other end in the bottom of the bottle submerged in the brake fluid.
Fill the master cylinder, open the bleeder and pump the breaks. You will be able to see the bubbles in the BF. As long as the tube stays submerged in the BF you will not get any air back into the system.
Watch the MC so it does not go dry. Do this to all four wheels and you should be OK.
Hope this helps
AC
Old Aug 28, 2008 | 11:34 AM
nodrogkam's Avatar
They do sell one man bleeder kits.
BTW looks great.
Hope all that labor and money makes a difference for you!
Old Aug 28, 2008 | 11:37 AM
DaBOM's Avatar
I agree, more yellow pics!!!
Old Aug 28, 2008 | 11:59 AM
GD3_Wagoon's Avatar
WORD!
more pics of your (RUBYQQ1211) yellow Fit please
Old Sep 6, 2008 | 09:02 PM
kancerr's Avatar
i want pics of the yellow too!
how do the brakes feel now?
Old Sep 6, 2008 | 09:17 PM
hey there was actually a thread where he showed pics of the paint.
looks so good on USDM
Old Sep 6, 2008 | 10:31 PM
redrumm's Avatar
dang looks so much better and im sure it feels better too.
Old Sep 6, 2008 | 10:58 PM
AtticusFit's Avatar
hey gotta question about this rear disk conversion..i did a brake upgrade on me civic hatch and also install rear disk on this app. you have to change out the MC and the proportion valve because drum brakes work at a higher pressure because on the line and bends,etc. also in this app i can cuase the pads to wear funny and/or drag...so is this the same case with the fits and if so is there a different MC and PV to use?
Old Sep 7, 2008 | 12:20 PM
gimme's Avatar
Master FitFreaker
oooh! x2
i would like to know this as well.
and, you dont happen to have part numbers off of each part in the conversion kit, do you?
Old Sep 8, 2008 | 01:07 PM
RubyQQ1211's Avatar
I have some issue with my brake also, still trying to fix them.
First is the right ebrake is stronger than left, I tried to pull ebrak on a small slope and can see that happen. The disc and brake pad also touch more on the right side, I can tell by the difference of rotating the wheels. I am assuming that the ebrake cable need to be adjust.
The other problem is on the left side. It makes noise sometimes when I hit the brake. It makes the noise in about 1 out of 10 braking. I think it's the pad retainer and the disc having contact.
Anyone got other ideas about it?
Old Sep 8, 2008 | 01:19 PM
AtticusFit's Avatar
these are some of the problems that you would run into the ek brake conversion if you did not replace the MC and PV.
this would be one reason for me not doing the t1r conversion on my fit.
bowtech83
Jul 6, 2012 01:32 PM
Mr08FiT
Jan 8, 2012 08:26 PM
avocado123
22
Nov 28, 2011 06:32 PM
feared
SoCal Classifieds
May 14, 2010 06:52 PM
Fit4Trav
Dec 6, 2009 06:22 AM
