HID too much glare
Old Jul 16, 2008 | 01:18 AM
soklean's Avatar
HID too much glare
i just bought a set of hid and installed em yesterday.. they work good but too good.. before i read the thread about adjusting the light was on the ground and the trees... it was too high even now after adjusting them the lights are pointed much much lower but the glare is still blinding... anyone know how to focus the lights??? because the lights are everywhere ... i no longer have the line where the headlight shines its more of a light blob... anyone have any suggestions.....
Old Jul 16, 2008 | 01:20 AM
solbrothers's Avatar
that is what HID's are. teh only way to get good use of that output is to do an HID retrofit. where you actually use the projector
Old Jul 16, 2008 | 02:01 AM
soklean's Avatar
would it help if i got the bulb thats hi/lo because it looks like it has some type of shield on it
Old Jul 16, 2008 | 02:02 AM
Will I Am fit.'s Avatar
Formerly "bitoy"
I agree!!!! and you probably have the kit that doesn't have the shield anyways, now that your headlight beam is screwed up I would suggest putting your stock bulb and try bringing back to the right aiming position on your headlights. follow this on how to aim your headlights here's the link Automotive lighting FAQ - Headlamp aiming
Old Jul 16, 2008 | 03:56 AM
soklean's Avatar
how do i find some headlights like the ones u have on ur icon
Old Jul 16, 2008 | 05:02 AM
Guinness's Avatar
I can give you some reference on how to aim your headlights. Before you start, pull your to about 2 meters away from a wall, then use a wrench or a (+) screw driver to change the aimming. If I remember correctly, I think turn left to aim low, turn right to aim high... but you get the idea... Best to do this in a parkade so there is no obstructions between your car and the wall
Once the focus of the lights (the brightest spot of the light hitting against the wall) are align to the point where its parallel to your headlights... Find a car and park behing it... should leave some room between you and the car in front of you... say around 1 to 1.5 meters.
The car, of cause, should be something like a Sedan and not a TRUCK or SUV. Now check your lights, and see if the bleeding line (aka The cut-off line for the light) should not not shine higher than the top of the rear bumper of the car in front of you.
If it is, readjust until its done correctly.
I apologize if my sentences are too wordy.. I'll try to provide some diagram next time...
Old Jul 16, 2008 | 08:06 AM
Formerly "bitoy"
That is a retrofitted headlights w/ the Q45 projector. It's custom made can't buy it anywhere you can have it done and IMO these are not cheap.
Old Jul 16, 2008 | 10:03 AM
Rod2Rice's Avatar
HIDs in a halogen housing is going to cause glare, no other way around it. The housing is not meant to accept an HID. You will hear others say it doesnt cause any glare, but that is just ignorance talking. Just because someone else doesnt flash you all the time doesnt mean there is no glare. I've used HIDs in halogen housings before, and it looked terrible. Removed them and got my $ back. Now as stated get yourself a projector light and the HIDs will look worlds better.
Old Jul 16, 2008 | 07:02 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
You must have bought a cheap kit or something? My headlights look perfect. I have a cut off and less glare than most OEM reflective (non projection) HID cars.
Also, I think my flat black headlight housings cut down the glare a bit too.
Old Jul 16, 2008 | 07:19 PM
rekcah's Avatar
What kit did you buy?
I agree cheap kits are defiantly not the way to go. My kit on the rsx ran me about $400 and had no more glare than your standard lifted truck or suv.
but I also had black housings on the RSX too.
Old Jul 16, 2008 | 07:23 PM
Posts in the NUUDE
Got it from HIDworld.com. Ive had it for about 2years now. I have the 35watt kit. Not the 55watt kit. I dont trust it.
My kit has a separate fused power wire that goes to the battery. From what Ive heard and read those are the best kits.
My friend got an HID kit for free for his 05 RSX. It was an 8000k. He ran it for a 6months, had a bunch of problems then bought the same kit (4300k) I have. WAY less glare and hasnt had a problem yet.
Arent the RSX housings gloss black though? My housings are flat.
I have almost zero glare.
Old Jul 16, 2008 | 07:43 PM
yeamans17's Avatar
That would have no effect on the glare, judging by your pictures you didn't paint the reflectors, and the light really wont do much off the housing itself, just the reflector.
Old Jul 16, 2008 | 07:48 PM
JDMchris.com's Avatar
I run THIS
Single beam HIDs cause more glare... Bi xenon will help alot. I had bi xenon with no virtually no glare. The same HIDs in my JDM conversion however glare a bunch.
Old Jul 16, 2008 | 07:49 PM
Posts in the NUUDE
I think it has something to do with it. My headlight housings are no longer glossy meaning theres no extra reflections. Paint on cars can reflect lighting. Not much but it can.
No the reflective housings arent painted. I wouldnt have light if I did that.
Old Jul 16, 2008 | 07:52 PM
Posts in the NUUDE
Why would Bi-xenon HID's have less glare? Its still HID capsules in a reflective housing. Do Bi-xenon kits have D2R style capsules? (reflective strip over the center)
I know some HID kits give you that option. The light output isnt an worse. The strip just prevents glare.
Old Jul 16, 2008 | 07:57 PM
I run THIS
every single beam Ive seen glares alot worse than the bi xenone. I think the bi xenon shield prevents the light from being reflected up too much. Cause when in low beam it reflects light downward... when you hit highbeam the shield turns and reflects light upward.
Old Jul 16, 2008 | 10:18 PM
wdb's Avatar
wdb
Yes. Take them out. The glare issue is exactly why reputable vendors of aftermarket lighting won't sell those infernal things. I snagged this link to the Hella website from Susquehanna Motorsports Home Page, local to me and a great source of lighting information:
Consumers | Hella USA and Canada
Old Jul 17, 2008 | 02:51 AM
soklean's Avatar
well can some of you post images of your hid if you have them on ur car and state if they are projectors or not and brand you have used..
Old Jul 17, 2008 | 03:05 AM
jeffquach's Avatar
i tossed my ebay ones in the trash the other day...lol
Old Jul 17, 2008 | 03:47 AM
Guinness's Avatar
I used to have bi-Xenon on my factory headlight housing... they work great, but the mechanism breaks down after 1-2 years and replacement is expensive... but that was a few years back
