T1R Crankshaft Pulley
Old Jul 19, 2008 | 09:47 PM
ericman20's Avatar
So I installed this pulley today and I thought there had been a little fitting issue, but after tightening the bolt, the pulley fit perfectly fine. I'm just a little paranoid now that there might be oil seal leak, etc etc but I was told it should be perfectly fine.
The car does pick up a bit, if you look at the tachometer you can see it pick up but you won't feel it pick up as fast as you see it. 1st, 2nd gear has improved, 3rd gear has improved only a tiny bit.
Anybody else have any input?
Old Jul 23, 2008 | 10:52 AM
Sugarphreak's Avatar
Push My Button
Sup Eric! I see you picked up a purple pulley
Just to clarify; An oil seal leak from the install or as a result of operation later on?
I don't think you will see any negitive impact, the only major concerns are premature wear on bearings for crank pulleys down the road.
Zangoose GD3 Blue
19
Jan 28, 2010 09:22 AM
Zangoose GD3 Blue
Oct 8, 2008 09:34 AM
08FitSport
17
May 29, 2008 10:34 PM
YeeFit
Jun 5, 2007 05:37 PM
jjeansonne
May 4, 2005 11:16 AM
