Replacing key assembly
Old Sep 14, 2005 | 10:30 AM
juandelecruise
Guest
Posts: n/a
I am having a problem with my 91 Accord (2-door 5-speed) ignition key
system. Looks like I have a worn barrel. I have to play with the key by
pulling/pushing a bit, twisting a bit, yanking a bit, cussing a lot, before
I could turn the ignition key on. This happens with all my spare keys too.
Can I salvage the key assembly from my 91 Accord Wagon automatic (which I am
junking) and slap it on the 2-door? Is the wiring harness the same?
Old Sep 14, 2005 | 11:30 AM
'Curly Q. Links'
Guest
Posts: n/a
Re: Replacing key assembly
Having two different keys is a royal pain. Just hose the lock full of
Lock-Ease and wiggle the key around. It will free up the gunk that's
preventing your lock from working correctly. It's messy (graphite) but
it really fixes locks. I use it on all five locks every year. I got it
at a locksmith, or a hardware. It has lasted for several vehicles.
'Curly'
Old Sep 14, 2005 | 12:30 PM
Abeness
Guest
Posts: n/a
Before you go nuts trying to deal with the lock cylinder, consider
whether all of your keys are worn (or perhaps improperly cut). The
dealer can issue a brand-new key based on your VIN number for just a
couple of bucks. They just did so for me, and it works great. Helluva
lot cheaper and easier than mucking around with the cylinder!
Old Sep 15, 2005 | 10:30 AM
Burt Squareman
Guest
Posts: n/a
"juandelecruise" <johndoe@large.com> wrote in message news:M6WVe.2607$6Z1.600283@news20.bellglobal.com.. .
There is an eject button on the key assembly you can push in and
eject the key cylinder. To do this, slip the key in, turn to ON and press
the recessed eject button the size of a pencil tip with a paper clip. Take
the cylinder out and look at the tumblers, if it's out of alignment file it
down and problem solved. Your first try to remove the cylinder should
be hard compared to 3 seconds for me.
One other method that might work is the ink pen and trial and error
method. I will leave this to your imagination.
I believe so. I believe this route requires an angle grinder, drill or the removal
of the steering column.
Old Sep 19, 2005 | 11:30 AM
juandelecruise
Guest
Posts: n/a
Thanks to all those who responded. I will take note of all your comments and
suggestions.
before
am
RixAE86
Feb 21, 2019 01:43 PM
Fr8Dog
Jan 14, 2019 11:48 AM
hookerfit
16
Aug 19, 2016 02:46 PM
tietack
Dec 2, 2008 11:42 PM
stevie
Jul 14, 2005 10:27 AM
