1992 Honda Accord - ABS Light Error Code
Old Sep 14, 2005 | 09:33 PM
jasguild@hotmail.com
Guest
Posts: n/a
HI
I have a 1992 Honda Accord. The ABS light has started to come on. If
I start the car, and dont drive it does not come on but after about 30
seconds of driving it comes on and stays on.
I followed the instructions in another post and used a paper clip to
short the connector by the passenger foot plate.
when I turned on the switch, all the dash lights including the ABS one
came on. Then the ABS light flashed 3 times.
Does anyone know what that code means??
Secondly, worse case scenario, if that code suggests the pump is gone,
(which I would not replace because of the $$$), is there a fuse or
breaker that I can remove to make the warning light go out?
Thanks for your help
jasguild
TeGGeR®
Guest
Posts: n/a
Re: 1992 Honda Accord - ABS Light Error Code
jasguild@hotmail.com wrote in
news:1126745439.375583.119210@g49g2000cwa.googlegr oups.com:
How long did you watch the light flash? It ought to flash a pattern
continuously.
If the pattern is indeed three flashes, then a repeat, it's Code 1. A host
of problems are identified by this code. See here:
http://www.tegger.com/hondafaq/misc/..._abs_codes.pdf
The specific pages for Code 1 are included in the PDF. If your code is
other than 1, I can post those too.
Yes, it's from a '93 Accord, but they ought to be the same as the '92.
A temporary workaround:
http://www.tegger.com/hondafaq/faq.html#ABS
TeGGeR®
Old Sep 15, 2005 | 12:30 AM
'Curly Q. Links'
Guest
Posts: n/a
jasguild@hotmail.com wrote:
> HI
You just proved that it's sensor-dependant, so clean the rust / grease /
dirt off your front tone rings and your troubles will probably go away.
Wire brush, being careful not to mangle CV boots.
'Curly'
Old Sep 18, 2005 | 08:30 PM
Guest
Posts: n/a
Curly
The I feel the same way the source of the problem. Like you I think
that if the code is not triggered until after I start driving, then it
has to be something to do with with moving ie the wheel sensor.
However the code is 1/2 which indicates its the pump.
Let me know your thoughts.
jasguild
Guest
Posts: n/a
> continuously.
> TeGGeR®
TeGGer
I reexamined the flashes and it is in fact a 1 - 2 sequence. I guess
that is bad news.
Is there any chance flushing the ABS system would help?
Is there any more convenient way to permanently disable that ABS light
if I end up not being able to solve the problem??
jasguild
Old Sep 18, 2005 | 10:33 PM
TeGGeR®
Guest
Posts: n/a
news:1127089322.868357.261400@g14g2000cwa.googlegr oups.com:
>> > one came on. Then the ABS light flashed 3 times.
>> continuously.
>> host of problems are identified by this code. See here:
>> is other than 1, I can post those too.
>> '92.
>> > gone, (which I would not replace because of the $$$), is there a
>> > fuse or breaker that I can remove to make the warning light go out?
>> TeGGeR®
> TeGGer
> that is bad news.
You're best to ask Comboverfish in rec.autos.tech, in that other thread you
started without correctly cross-posting to this one. Good thing I found
that other thread. I felt foolish posting a reply without knowing you had
someone else working on it too.
The manual says it could be the motor relay, unit fuse, or motor fuse. Have
you checked the fuses? Relays and fuses are not particularly expensive or
difficult to replace.
TeGGeR®
Old Sep 18, 2005 | 11:30 PM
Guest
Posts: n/a
I guess I will expose my ignorance even more but I apologize for making
you feel foolish. I somehow thought it was two unrelated different
locations. I tried to post in the two locations to be able to get as
much feed back as possible.
Is it poor etiquete to make multiple post of the same issue? Secondly
how do I cross post??\
Thanks
jasguild
TeGGeR®
Guest
Posts: n/a
news:1127096599.533856.307510@z14g2000cwz.googlegr oups.com:
It is considered correct to crosspost to (up to!) two or three groups that
are /directly/ concerned with the post you're making.
In Mozilla/Netscape/Thunderbird, you manually add the other groups below
the one you're posting to. It's also considered polite to state in your
message that it's been cross-posted to whichever group(s).
TeGGeR®
Old Sep 19, 2005 | 12:30 AM
Guest
Posts: n/a
Thanks for the edification. I post using google.com groups not via a
soft ware. I dont see any cross post option. Is it too late to cross
post this one??
A couple other questions. I read the pdf file you referenced and i am
doing the tests it suggests. However, I dont know where
1)the fail safe relay is located
2) the abs pump motor connector?
Can you describe to me or if you have one send me a link or pic on
where I would find these two items. The article does not say and my
Haynes manual is likewise silent.
Thanks
jasguild
jasguild555@yahoo.com (REMOVE THE 555. Its just there to keep out the
spammers.)
Old Sep 20, 2005 | 06:37 PM
TeGGeR®
Guest
Posts: n/a
news:1127100382.228537.314520@z14g2000cwz.googlegr oups.com:
> post this one??
Next to the Control Unit, in the trunk against the right-side wall.
All I've got:
http://www.tegger.com/hondafaq/misc/...-locations.pdf
http://www.tegger.com/hondafaq/misc/...lectronics.pdf
TeGGeR®
Old Sep 30, 2005 | 11:30 AM
Comboverfish
Guest
Posts: n/a
His ABS code proves that you are incorrect.
Toyota MDT in MO
doctor J
Oct 21, 2016 10:41 AM
phoenity
Sep 22, 2015 04:03 PM
Santiad
Mar 27, 2013 10:44 AM
Trying to Help
Oct 10, 2005 12:32 AM
jazzy29
Oct 8, 2005 11:35 AM
