91 Honda losing brake fluid
Old Sep 19, 2005 | 11:30 AM
utahgolfer
Guest
Posts: n/a
I have a 91 Honda Accord, great car. However recently I have been
losing brake fluid. About one a week I have to fill the reservoir.
Now here is the kicker. I have checked and had it checked by multiple
mechanics and there are no leaks in the system that I (or they) can
see. And there is nothing on the garage floor after parking there.
Very wierd. Anyone seen anything like this or know of any other
explanation? Any help is appreciated.
Old Sep 19, 2005 | 05:30 PM
Abeness
Guest
Posts: n/a
Re: 91 Honda losing brake fluid
> see.
Chances are it isn't gonna leak out when sitting, but under pressure.
There's obviously a leak somewhere. Try pumping like crazy while
sitting, then trace and check the lines, master cylinder, and
calipers/wheel cylinders again. Could be leaking in a place where it
doesn't drip right away. Take the wheels off, of course, and maybe even
remove the calipers to get a closer look at the piston seals.
Old Sep 19, 2005 | 06:39 PM
Abeness
Guest
Posts: n/a
Just DON'T pump like crazy with the calipers removed, or you could eject
the pistons!
Old Sep 19, 2005 | 10:31 PM
jim beam
Guest
Posts: n/a
probably leaking into the vacuum servo or inside the car from the master
cylinder - not usual that it happens like that, but it can. all other
leaks should be obvious. check /all/ brake lines & hoses as well as
calipers, drums, etc.
Old Sep 19, 2005 | 10:38 PM
CR50HC's Avatar
My car had a similar problem. Turned out to be a loose brake hose on the right rear drum. The fluid was dripping ever so slightly from the hose and running down the inside of the rim. Very difficult to notice.
Old Sep 20, 2005 | 01:37 AM
SoCalMike
Guest
Posts: n/a
>> see.
any way it could be sucked thru the vac port on the brake booster, and
burned by the engine?
Old Sep 20, 2005 | 08:32 AM
Abeness
Guest
Posts: n/a
Probably? ;-) I haven't seen that myself, but it sounds reasonable. My
experience is far from complete.
Old Sep 20, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
>>> see.
>> even remove the calipers to get a closer look at the piston seals.
the servo would have to be mostly full to do that - the vacuum port is
at the top on the 91!
Old Sep 20, 2005 | 03:30 PM
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in news:28udnfMQZoZO8LLeRVn-
gQ@speakeasy.net:
HIGHLY unlikely it's leaking into the booster. Two O-rings seal that end up
awfully well. And it cannot leak into the car at all unless it first fills
up the booster then perforates the diaphragm, then fills up the other side
as well.
I think the OP has a holed line or it's leaking out of a caliper or into a
drum (if so equipped). Drums must be /removed/ to check.
Have helper step HARD and steadily on pedal, and watch underneath for
drips. If leak is mild, wind will sweep fluid away at speed. Best to have
car on hoist & have strong light. Hold pedal for five minutes or more.
Does car have ABS?
Additional slightly possible source of leaks is base of reservoir. If clamp
is loose or body is corroded, fluid can seep past.
Does car have other leaks that could obscure leaking brake fluid?
TeGGeR®
www.tegger.com/hondafaq/
Old Sep 20, 2005 | 11:37 PM
jim beam
Guest
Posts: n/a
> gQ@speakeasy.net:
> as well.
i've seen it. not on a honda, but i have seen it.
> Does car have ABS?
Old Sep 21, 2005 | 08:31 AM
TeGGeR®
Guest
Posts: n/a
news:7N-dnenIqeA6Va3eRVn-tQ@speakeasy.net:
>> end up awfully well. And it cannot leak into the car at all unless it
>> first fills up the booster then perforates the diaphragm, then fills
>> up the other side as well.
Some MC designs (especially older unboosted designs) did not seal the rear
of the plunger well. Those can leak into the car.
The Honda MCs I've seen have all had a rear plug with two O-rings. Leakage
from that is VERY rare. And even then it would have to fill up both sides
of the booster before leaking into the car. The booster could hold an awful
lot of fluid.
He's got a leak somewhere else, I'm convinced. Just nobody's finding it.
TeGGeR®
Old Sep 22, 2005 | 04:30 PM
roadcyc@socal.rr.com
Guest
Posts: n/a
My money is on: fluid leaking into the vacuum booster.
Old Sep 22, 2005 | 08:30 PM
TeGGeR®
Guest
Posts: n/a
roadcyc@socal.rr.com wrote in
news:1127419447.063791.319070@g43g2000cwa.googlegr oups.com:
Basically, that's completely impossible. The rear chamber has no pressure
in it.
http://www.tegger.com/hondafaq/maste.../howworks.html
TeGGeR®
Old Sep 22, 2005 | 11:30 PM
jim beam
Guest
Posts: n/a
not so - it's extremely common for the bore seal to go. look around a
junk yard and you'll see boosters with leakage evidence [missing paint]
all the time. the question is whether it will leak /into/ the booster,
and while the honda booster has a drain where the cylinder is mounted to
mitigate this, it can still happen. it depends on how greased up the
original seal was and whether the drain is plugged.
> in it.
doesn't need it. in fact, seals don't leak much under pressure because
they get pressed against the cylinder wall. it's seepage from when the
seals are relaxed that is the biggest problem.
Old Sep 23, 2005 | 10:31 PM
utahgolfer
Guest
Posts: n/a
Thanks for the info I hve pumped and pumped but see no leaks. I am
going to pull the wheels next and see what I can see
utahgolfer
Guest
Posts: n/a
No idea on being sucked thru the vac port not sure what that is even.
utahgolfer
Guest
Posts: n/a
How can you check the booster?
utahgolfer
Guest
Posts: n/a
I will remove the drums and look again at everything. Yes it has ABS.
No other leaks.
Bulldozer27
Jun 12, 2023 12:50 PM
sailorman2439
Oct 2, 2016 04:43 PM
sailorman2439
Aug 25, 2016 12:04 AM
AppleMac*Fit
Nov 14, 2010 01:40 PM
chibitul
Jul 24, 2005 05:32 AM
