Rear Civic wheel bearing update.
Old Sep 20, 2005 | 11:32 AM
r2000swler@hotmail.com
Guest
Posts: n/a
I had a chance to check my friend's car. The main source of noise
was the tire, but there is more noise from that wheele then from
the other side or either of mine. He only drives around own at
speeds of less then 45 for short distances. When he gets his next
disability check at the first of Oct he will order a replacement
from Manchester Honda. The local consensus is that the bearing is
very unlikely to sieze under the driving conditions I have discribed.
I am a little leary but it is his car not mine.
What are the chances that he will be able to get away with what
I consider to be an insane, or desperate, course of action?
Thanks for the advice and comments. It is not going to be near as
tough as I feared. He had teh rear brakes shoes replaced in the
spring and teh drum shoudl come "right off".
Or at least hat is my hope.
Terry
Old Sep 20, 2005 | 12:30 PM
'Curly Q. Links'
Guest
Posts: n/a
Re: Rear Civic wheel bearing update.
> Terry
I was surprised to find you can get wheel bearings (hub) from places
like NAPA and Canadian Tire. WAY cheaper.
'Curly'
Old Sep 20, 2005 | 03:30 PM
TeGGeR®
Guest
Posts: n/a
r2000swler@hotmail.com wrote in
news:1127227421.562805.274210@g44g2000cwa.googlegr oups.com:
Jack up the wheel and spin it by hand. If the bearing is bad, you'll know
right away (rumble rumble).
Those rear bearings don't go bad very often, since they are well-protected
from the weather, unlike the fronts.
TeGGeR®
www.tegger.com/hondafaq/
Old Sep 20, 2005 | 08:30 PM
Guest
Posts: n/a
know
well-protected
TeGGeR®
In a post some time ago in thsi NG I think you mentioned
that an unloaded wheel bearing could be silent.
This one is "silent" tothe ear. I am going to use a
high gain mic/amp to listen to weak sounds. If
nothing else I am learing "stuff" that might help
myself someday. I have to dig out an electronic
stethoscope I built 3+ decades ago that used a
crystal phono cartridge coupled to a uA709
for just this task. At the time my Honda CB350
was acting funny and I suspected the front wheel
bearings.
Would you agree the risk of the bearing siezing is
minimal with the conditions Istated?
Terry
Old Sep 20, 2005 | 09:30 PM
TeGGeR®
Guest
Posts: n/a
news:1127260560.050637.271150@g43g2000cwa.googlegr oups.com:
>> know
>> well-protected
Not me. Every bad bearing I have personally encountered was either rough to
the hand when spun, or rumbled audibly. I'm sure some are silnet, but I
don't know how common that is.
Bearings normally go bad for three reasons:
1) Water ingress that causes rust (fronts are prone to this), or
2) impact that damages the balls or puts little dents in the races, or
3) the surface of the balls starts flaking off from compression stress
(typical of transmission bearings).
All of these conditions normally result in noise.
<snip>
Yes. Very minimal.
But...Tell your friend to keep an ear out for odd noises. If he suddenly
starts hearing a very loud howling from the rear, STOP THE CAR IMMEDIATELY!
TeGGeR®
Old Sep 21, 2005 | 10:31 AM
Guest
Posts: n/a
rough to
<snip>
Yes. Very minimal.
suddenly
IMMEDIATELY!
TeGGeR®
I have relayed your comments to him and I am certain he will follow
the advice. I will not be able to get over unitl Sat afternoon, I will
test it
and post the results here. I found my usper doper eletcronic
stethyscope and it still works! I intend to jack my car up and listen
to what I think are good bearings to get a feel for how "noisy" they
are.
I ambettingthat one could capture the soundandrun it through a PC
wiht an audio FFT/waterfall program and detect war long before
failure.
Terry
Glockbag
Jul 20, 2015 08:01 AM
MTLian
Apr 20, 2015 03:51 PM
g fit
May 9, 2014 05:48 PM
Eamper
Mar 11, 2011 07:27 AM
May 4, 2005 11:16 AM
