These rims specs, prob on stock height?
Old Aug 4, 2008 | 09:12 AM
Luichenwai's Avatar
Size 15x6
4x100
Off set 38
Center Bore 56.1
Will I have any problems with this size rim when riding on stock springs?
Old Aug 4, 2008 | 10:15 AM
MNfit's Avatar
At stock ride hight im sure you will be fine
Old Aug 4, 2008 | 10:17 AM
Luichenwai's Avatar
yeh thats what im thinkin too.
Old Aug 4, 2008 | 01:31 PM
Fitcapo's Avatar
stock height you should be ok.
Luichenwai's Avatar
anyone with a definite answer? lol.. too many ifs.. and shoulds..
Old Aug 4, 2008 | 03:37 PM
mahout's Avatar
Originally Posted by Luichenwai
Size 15x6
4x100
Off set 38
Center Bore 56.1
with stock springs and tires all you are doing is moving the whole wheel and tire outbound by 55-38 mm or 17 mm or .67" You can check easily with a ruler or see if a 5/8" thick board will slip easily vertically lightly against the sidewalls up into the fender.
However I don't believe the centerbore is OK; believe it needs to be more than 65 mm. That too you can check on your wheels.
Too you need to see if the wheels fit over the calipers with at least 2 mm clearance al;l around.
An alternative is 1/4" spacers between the wheel and hub to move the tires out 12 mm to look better in the well well. Just make sure the thread engagement is equal to at least the lug bolt diameter. Spacers are typically $20 or so per set and widen track by 1/2" .
NotBlake
Jan 23, 2015 09:59 AM
GC617289
Jul 1, 2014 08:24 PM
vythai
Aug 10, 2011 08:50 AM
strmslvrfit
Oct 20, 2008 03:46 PM
MemphisFit
Aug 30, 2008 01:18 PM
