Amp help
Old Aug 15, 2008 | 11:20 PM
o0ZeroGravity0o's Avatar
Amp help
I am wondering if the stock radio for the honda fit sport has any port that can be used to put a amp for bass. Or if there is anyway of doing it with the stock one. Please help this newbie.
Old Aug 16, 2008 | 12:30 PM
mrwilli1's Avatar
You will need to install a Hi-Lo converter to run an aftermarket amp with the stock HU.
Check with installer.com
Old Aug 16, 2008 | 02:01 PM
Fitting's Avatar
You could get an amp that take speaker level input (you use the speaker wires to feed signal to the amp).
Old Aug 16, 2008 | 06:08 PM
i got a high - low converter, so that means all i need is to install it?
Old Aug 16, 2008 | 08:11 PM
feared's Avatar
just need power wire, ground, rcas, etc. to install it. but with the hi/low converter you should be able to get a signal to the amp with rcas, and just set the crossover accordingly and u should be set
Old Aug 17, 2008 | 12:11 AM
mrwilli1's Avatar
Before removing the HU from the dash, you should search the forum for directions. The key is NOT to pry from the outside. I guaranty you will damage the dash. Also, after removing the assembly, be sure to purchase 7 NEW clips for the re-install. They tend to fly off and get lost and are intended for one time use only.
Good luck...
Old Aug 17, 2008 | 12:21 AM
radareclipse's Avatar
Or, you could take it to a qualified car audio shop in PR.
Welcome to the forum!
Old Aug 17, 2008 | 12:40 AM
nxtfit_08's Avatar
do the hi-low converter its the best way to go also shouldn't void warrenty so I've been told I did it and sounds good! I ran it off the rear speakers instead of risking to take the dash apart just get the wiring diagram and do it that way
Old Aug 17, 2008 | 01:07 AM
This mod has nothing to do with challenging the warranty, so no worries.
Old Aug 17, 2008 | 05:26 PM
Thanks for all the help. At the end i decided to make something up that i saw for making an amp useful in a house. And here goes the idea that i saw. They used a power supply to power up the amp and the radio, and any other 12volt item. They put out this diagram which i took, its not made by me. Name:  inroomamp.jpg
Size:  10.6 KB And so i though, why dont i do that to make it easy to mount my amp. And i already had a power converter, which made the 12volt ac from batery 120volt dc. Here is a picture that I took of my power converter. My mp3 had a adapter to make it 2 lines out, one line goes to the car radio input; the other goes to the amp. Name:  P7170009.jpg
Size:  15.7 KBConnected to my power converter i got a computer power supply, with the mod shown in the first picture. And here is the final product. It works decently, plus i can connect anything in the other ports of the compuer power supply because each connector has 12volts. Hopefully i will get some neons there. Name:  P7170010.jpg
Old Aug 17, 2008 | 07:06 PM
I think I'm following you. If so, I hope your fuse blows before something catches fire. How many watts is the power inverter? What is the REAL wattage of your amplifier at 12 volts, wattage at 14 volts?
shazaam's Avatar
Thanks for all the help. At the end i decided to make something up that i saw for making an amp useful in a house. And here goes the idea that i saw. They used a power supply to power up the amp and the radio, and any other 12volt item. They put out this diagram which i took, its not made by me. And so i though, why dont i do that to make it easy to mount my amp. And i already had a power converter, which made the 12volt ac from batery 120volt dc. Here is a picture that I took of my power converter. My mp3 had a adapter to make it 2 lines out, one line goes to the car radio input; the other goes to the amp. Connected to my power converter i got a computer power supply, with the mod shown in the first picture. And here is the final product. It works decently, plus i can connect anything in the other ports of the compuer power supply because each connector has 12volts. Hopefully i will get some neons there.
that's sorta nasty looking compaerd to just a hi lo converter add on :/ I mean, high five for the idea and execution but def. more complicated and messier than wires normally needed for an amp ran underneath trim. Guess you could with yours but no where really to hide the PSU...cept spare tire area.
Old Aug 17, 2008 | 07:49 PM
The power converter auto shuts down if anything is abnormal, and i dont really understand the wattage question, cause i am giving my amp 12 volts just like the battery, tho bateries tend to have a lil more power. Still sounds nice, and as i think i said this is for a time only, and for some testing. I could just add on a computer in my fit, i got all sorts of extra parts of computers and who knows what i might make in there :P
Old Aug 17, 2008 | 10:38 PM
Is your power converter plugged into the cigarette lighter plug? The converter has a three prong plug coming out of it, right? That's what I think I'm looking at. What kind of amplifier do you have hooked up to it? Home or car audio amp?
Old Aug 17, 2008 | 10:41 PM
i got a computer power supply conected to the power converter. And yes its conected in the cigarret plug. The amp is for car.
Old Aug 18, 2008 | 04:59 PM
boon4376's Avatar
Thats really messy and unnessary, why not just run 1 normal wire to the battery?
Old Aug 18, 2008 | 05:49 PM
I felt creative... lol And since you guys deserved it to look less messy, i came up with another idea. I made this prototype box for the computer power supply. I know its still unpainted or unwrapped by anything, but its the concept what i wanna show. Name:  Picture016.jpg
Size:  11.9 KBThats made by me, and here is what it looks like in a real picture. Name:  Picture017.jpg
Size:  13.1 KBAs you can see i still got 3 ports with 12 volts, and got like 2 more ports hidden at the back.
ck42
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
13
Jul 14, 2017 12:11 PM
Wafulz
Fit I.C.E.
Nov 3, 2013 01:58 PM
mdsniper7
Feb 18, 2012 07:00 PM
WhiskeySix
May 17, 2011 08:19 PM
itfits12
Dec 18, 2007 09:35 PM
