Torque Settings For Struts
Old Aug 18, 2008 | 01:42 PM
gd3_is_go!'s Avatar
I was wondering if any of you guys knew the exact torque settings in in-lbs or Nm for the front and rear strut mounts. I'm going to install some cusco bars this weekend and I'm just one of those people who has to do it by the book... but, i'm too broke to buy the shop manual because i just bought the strut bars...lol. anyways any help would be much appreciated!
- Jon
Old Aug 18, 2008 | 01:50 PM
front top mount 33lbs/ft
rear shock top 22lbs/ft
Old Aug 18, 2008 | 01:58 PM
gd3_is_go!'s Avatar
ahhh, thank you sir!
Old Aug 18, 2008 | 02:09 PM
man, this site is frikken slow to load.
the cusco front stb doesnt touch the front strut top nut and use
new nuts/bolts included in the package. use 22-25lbs for those
along with some loctite blue.
there may have been a listing in the package for the amount of
torque. it's been a while since i did the install.
Old Aug 18, 2008 | 05:30 PM
mahout's Avatar
- Jon
In the front there are 2 nuts; the lower one is 12x1.25 mm over the bearing and torqued to 25 lbft and the upper 12x1.25 torqued to 33 lbft. The shock flange nuts are 14x1.5 mm torqued to 75 lbft. These are recommended to be replaced because they can be easily stretched at 75 lbft.
the rear upper nut is 10x1.25 torqued to 22 lb-ft and the lower cross bolt is 10x1.25 mm torqued to 40 lbft.
Please note these are lbft not inlb. If you use inlb multiply by 12 (25 lbft becomes 300 inlb.)
Old Aug 18, 2008 | 05:42 PM
yah, the front cusco stb doesn't use the piston shaft nut...
i remembered after posting the torque ratings for the strut
and rear shock.
i guess i'll post the rates i have in my blackberry:
FRONT:
Bottom (2) on the knuckle 50lbs/ft
Top between the mount 25lbs/ft (per mahout above)
Very top nut 33lbs/ft
Endlink: 21lbs/ft
REAR:
shock bottom: 40lbs/ft
shock top: 22lbs/ft
Old Aug 19, 2008 | 02:20 AM
gd3_is_go!'s Avatar
sweet. thanks fellas. i appreciate it!
DanMarino
Jul 16, 2016 01:03 PM
MNfit
28
Aug 21, 2010 09:28 PM
revd34
70
Jul 15, 2009 02:40 PM
keepitpg
Jan 19, 2009 04:52 AM
MNfit
13
Jan 1, 2008 04:41 PM
