1984 Accord with fuel problem
Old Oct 10, 2005 | 02:30 PM
bayneman
Guest
Posts: n/a
i replaced the fule pump and fuel cut off relay, but fuel pump still not
doing its job and car will not start. There is spark and engine turns
over. What else can I check?
Thanks!
Old Oct 10, 2005 | 03:30 PM
mmdir2005@yahoo.com
Guest
Posts: n/a
Re: 1984 Accord with fuel problem
Try Starter and check battery.
Old Oct 10, 2005 | 04:33 PM
bayneman
Guest
Posts: n/a
Starter was replaced earlier and works fine. Battery was weak, so jumped
yet still no fule to engine. I pulled the fuel line at the engine and no
fuel reaching that point. Fuel pump shoots one squirt of fuel, then does
nothing else. To test, I hard wired power to the fuel pump and even that
did nothing. What else could it be???
Old Oct 10, 2005 | 06:30 PM
Misterbeets
Guest
Posts: n/a
Checked fuel line and filters?
Old Oct 11, 2005 | 08:30 AM
Burt Squareman
Guest
Posts: n/a
"bayneman" <wnbateman@excite.com> wrote in message news:42cca62754130d3a564653ebca4b42ff@localhost.ta lkaboutautos.com...
Gas filler cap clogged?
Check for pressure before the filter located on driver side rear tire.
Old Oct 11, 2005 | 10:35 AM
bayneman
Guest
Posts: n/a
Gas is getting through main filter to the fuel pump fine. I will check to
mke sure fuel line downstream of fuel pump is clear (should be). Real
issue seems elelctronic as fuel pump is not actually running at start up
as it should. Does this year have an ECU?
THANKS for help!!!
Steven Hung
1290
Jul 6, 2022 10:02 AM
BMW ALPINA
Feb 3, 2018 12:27 PM
blackgd3
Jul 10, 2007 11:33 AM
Fit of RAGE
Feb 26, 2007 10:14 PM
cocococo1
Jun 23, 2005 11:43 PM
