Throttle body
Old Oct 11, 2005 | 04:30 PM
gearshift
Guest
Posts: n/a
Throttle body
The problem I am experiencing is that the throttle body on my 1994 accord
EX is full of carbon deposits. I cleaned the throttle body last month . I
only drive about a thousand miles a month. What could be the cause of this
problem. Thank you in advance...
Old Oct 11, 2005 | 08:30 PM
TeGGeR®
Guest
Posts: n/a
Re: Throttle body
"gearshift" <hotred1@earthlink.net> wrote in
news:61088c8bd4ad01727dbad71cfb8e3f3d@localhost.ta lkaboutautos.com:
> accord EX is full of carbon deposits. I cleaned the throttle body last
> month . I only drive about a thousand miles a month. What could be the
> cause of this problem. Thank you in advance...
Is it dry, dusty carbon, or goopy, oily carbon? If the latter, your cause
is lack of timely oil changes, and thus sludge and a plugged PCV valve.
TeGGeR®
www.tegger.com/hondafaq/
Old Oct 11, 2005 | 10:30 PM
gearshift
Guest
Posts: n/a
Re: Throttle body
the throttle body is dry and dusty. No goop or oil deposits..
gearshift
Guest
Posts: n/a
Re: Throttle body
The throttle body is dry, dusty carbon.No oil or goopy residue..
Old Oct 11, 2005 | 11:36 PM
TeGGeR®
Guest
Posts: n/a
Re: Throttle body
>> cause is lack of timely oil changes, and thus sludge and a plugged
>> PCV valve.
Then don't worry about it. Dry, dusty carbon is normal.
However, if you feel there is enough in there to affect throttle response
and idle speed, look for air leaks into the intake tube, and change your
air filter with a new OEM one.
TeGGeR®
frui7cak3
Jul 27, 2014 03:03 PM
Marrk
Sep 14, 2013 01:25 PM
Remould
May 29, 2012 11:39 PM
alf74
Jul 25, 2006 02:30 AM
kimo
Dec 20, 2005 04:12 PM
