Craftsman timing lights--which one?
Old Oct 12, 2005 | 10:30 AM
Abeness
Guest
Posts: n/a
Sears offers two "heavy duty" timing lights, one for $50 and one for
$70. The description of the more expensive one notes "0-60 degree
advance scale for more accurate and easy timing measure". Is this a
useful feature, worth another $20? Or will the $50 one be sufficient?
I've never checked timing before, but am competent.
Also, I'm assuming that the Craftsman Engine Analyzer is a reasonable
choice for checking engine rpms. Would anyone suggest otherwise? Thanks.
Old Oct 12, 2005 | 12:35 PM
Elle
Guest
Posts: n/a
Re: Craftsman timing lights--which one?
Last year I inquired here about timing lights. The consensus was to buy the
cheapest one possible. See the reasoning in the thread at
http://1tiny.com/306
Ebay has some very good deals on timing lights.
Old Oct 12, 2005 | 01:32 PM
Misterbeets
Guest
Posts: n/a
Look at http://www.iequus.com/item.asp?cid=20 first.
Old Oct 12, 2005 | 02:30 PM
'Curly Q. Links'
Guest
Posts: n/a
Not entirely perfect advice, because the 'cheapest one possible' is not
worth backing over with your Honda, because it isn't electronic . .
It's just a flash tube that runs off your high tension ignition spark,
and you have to use it at night.
Been there as a teenager, waited until dark.
'Curly'
Elle
Guest
Posts: n/a
"'Curly Q. Links'" <motsco__@interbaun.com> wrote
the
Yes, I guess I should have mentioned cheapest _induction_ timing light
available. Induction timing lights being the type that have a lead clamping
around an ignition wire.
Old Oct 12, 2005 | 03:32 PM
Mike Iglesias
Guest
Posts: n/a
In article <434D5028.ADC065E1@interbaun.com>,
The one I had as a teenager worked in my parent's garage...
Mike Iglesias Email: iglesias@draco.acs.uci.edu
University of California, Irvine phone: 949-824-6926
Network & Academic Computing Services FAX: 949-824-2069
Old Oct 13, 2005 | 09:30 PM
Abeness
Guest
Posts: n/a
Thanks, guys. Excellent info. Looks like those Equus folks make a
cheaper tach, too:
http://www.iequus.com/item.asp?cid=40
Do I need a code reader for a 94 Civic EX? I was looking for one awhile
back, and now see that these guys make one.
I'll check ebay for a light.
Old Oct 14, 2005 | 02:32 PM
do_not_spam_me@my-deja.com
Guest
Posts: n/a
Abeness wrote:
> Looks like those Equus folks make a cheaper tach, too:
Any tach that doesn't use either an internal battery or the car's
battery for power will not give accurate readings, except by chance.
That model 3010 tach looks like a tach I bought for $5 long ago that
was off by 20%, and I ended up gutting its circuitry and substituting a
proper tach circuit from an electronics magazine.
Pre-1996 cars generally have ways to read codes without any special
equipment, and I believe Hondas made even after that year allow this,
at least to a limited extent. Factory and Mitchell manuals cover this
area much better than Haynes and other third party manuals do. However
if your 1994 is similar to a 1995, here's free access to a factory
manual:
www.honda.co.uk/owner/CivicManual/
Klasse Act
Jul 24, 2021 02:21 AM
jmains89
Jul 23, 2021 10:59 PM
pNz
Nov 8, 2009 04:14 AM
CarDemon
Oct 28, 2009 02:23 PM
Blackhill
May 4, 2005 11:16 AM
