94 civic 1.5L
Old Oct 12, 2005 | 10:30 PM
Rocky
Guest
Posts: n/a
94 civic 1.5L
new battery, alternator less than 2 months old - yesterday, the tach and
speedo started to bounce when the signal was turned on - AAA says alternator
went bad - why didn't my battery light come on? the bulb is good.
Old Oct 13, 2005 | 12:30 AM
'Curly Q. Links'
Guest
Posts: n/a
Re: 94 civic 1.5L
It's not your alternator . . Take a look at tegger's FAQ
www.tegger.com/hondafaq/
I'm sure you'll find your answer (and many more).
'Curly'
Old Oct 13, 2005 | 01:31 AM
TeGGeR®
Guest
Posts: n/a
Re: 94 civic 1.5L
"Rocky" <jcadellano.spam@optonline.net> wrote in
news:0pj3f.22087$Ge5.11593@fe10.lga:
> and speedo started to bounce when the signal was turned on - AAA says
> alternator went bad - why didn't my battery light come on? the bulb
> is good.
The charge light will come on if there is NO output from the alternator. If
it's charging too little--or overcharging--the light will not come on.
TeGGeR®
Old Oct 15, 2005 | 03:30 PM
Rocky
Guest
Posts: n/a
Re: 94 civic 1.5L
I forgot I posted here and I am attempting to remove the alternator since
the parts store gave me a replacement. I think I have to remove the exhaust
pipe to make enough clearance to remove the alternator. I find the main
wire is melted at the terminal of the alternator and the insulation a couple
inches up the wire has bubbled.
I'll check the tegger faq before I go further.
I also decided to add a real voltmeter as AutoZone didn't have an add-on
ammeter to install.
"Rocky" <jcadellano.spam@optonline.net> wrote in message
news:0pj3f.22087$Ge5.11593@fe10.lga...
> alternator went bad - why didn't my battery light come on? the bulb is
> good.
Rocky
Guest
Posts: n/a
Re: 94 civic 1.5L
The only thing I found in the faq was possibly a bad battery if it goes
flat, but mine is holding a charge. I'll continue with removing the
alternator.
"'Curly Q. Links'" <motsco__@interbaun.com> wrote in message
news:434DD6AA.268E1E60@interbaun.com...
>> alternator
> 'Curly'
lister
Mar 8, 2020 12:58 PM
Tymd
Mar 16, 2017 08:24 AM
ParrotQueen
Sep 9, 2005 04:32 AM
Remco
May 4, 2005 11:16 AM
ssampage
