CVT vibration - help?
Old Oct 31, 2005 | 04:13 AM
vtec's Avatar
Hi,
I have just got my Jazz/Fit, and have noticed a vibration when moving off from a dead stop. It doesnt do it when the engine is cold, first thing in the morning.
I have read on the net that it may be the CVT fluid being ATF-Z1, and it should be changed to Honda CVTF. Or it may be a problem with the 'start up clutch', whatever that is. Has anyone had this problem, or has heard of it?
Thanks.
2002 Fit 1.5 Vtec CVT (Vivid Blue)
Old Oct 31, 2005 | 04:28 AM
vividjazz's Avatar
Someone that Posts too much
Your vehicle should still be under 3 year warranty. You should get it checked over before the warranty expires.
Have you changed the fluid since new at all? How many kms have you done?
Old Oct 31, 2005 | 02:47 PM
vtec's Avatar
Hi,
Vehicle is Jap import, warranty ran out yesterday (warranty not transferable anyway). I doubt the fluid has been changed. It has done 28000 kms.
Old Oct 31, 2005 | 05:14 PM
vividjazz's Avatar
If its an ex Japan car its probably spent alot of its time idleing in traffic (alot more stressful that alot of kms on the clock - think life of a taxi which spends alot of time waiting).
Drop the tranmission fluid and see what it looks like. Put the required 3L+ of new genuine Honda branded fluid in and see how it goes. More than likely it will do the trick.
If it was an Japanese import the 1st thing I would have done when I got it was drop every fluid, oil, coolant, brake fluid, transmission fluid and replaced all filters air, oil, fuel. Full inspection of plugs, clearances, brake pads, suspension, the works.
I've seen 4 year old Toyotas with solidified oil (hard as a rock) in their engine come in from Japan which appear to haven't had any maintenance and a very hard life.
Old Nov 1, 2005 | 02:39 AM
vtec's Avatar
Hi,
Did all the fluids yesterday, and full service checks. Except cvt.
picked up 4L of ATF-Z1 today. Honda hadnt heard of the new fluid
CVTF. Have any Honda dealers in Aus heard of it that you know of?
Cheers.
p.s. Where did you get your double din? Evolution-R in Victoria say they have them for AUS$130. Do you know anywhere better?
pps. What is the little symbol with 'clock' written below it on the inbuilt dash? Is it the reversing sensor? Mine just comes up 1640, which I think means not installed?
Old Nov 1, 2005 | 03:11 AM
vividjazz's Avatar
Can't get the CVTF through Australian Honda dealers either. Honda Australia doesn't bring in a heap of the Honda lubricants that are available in Japan and are generally pretty hopeless.
Wouldn't be a problem for me though as there is one Honda specialist in Sydney called Hannys Performance who services my car and he can get everything and anything for Hondas. He brought in some special Honda ultra high performance race oil for my bike that I can't even find a reference for on the Honda Japan website or HRC but it is just magic stuff (revs like something from a Honda works team).
I brought the double DIN in from Thailand (love that Australia-Thailand free trade agreement - FTA). A$130 is an ok price if it includes the necessary double DIN mounting brackets. JDMYARD have them for about $120 as do a couple of other places I know of.
I don't know about the little symbol your refering to. Would you be able to post a picture. Is it a Japanese character or a picture? If its a kanji character I can easily have it translated if I see a pic as it will only be in hiragana. The Oz Jazzes don't have the reversing sensor and don't offer it as a factory option so might not have that display if its related to that.
When your doing the tranmission fluid be very careful not to overfill it. It should take a bit over 3L but certainly not a full 4L. Bit rough how they only sell the stuff in 1L containers.
Old Nov 1, 2005 | 10:57 PM
vtec's Avatar
Hi,
thx for that. Good news, changing the CVT fluid fixed it!
Funnily enough, it took 4L. They left it draining for 3 hrs...
It is now available (as of last week) in 4L containers!
I paid $56NZ for 4L of ATF-Z1.
The little button is not kanji, but a dot, with a ever increasing sized vertical lines radiating away from it. sort of .<
Gotta be radar/sensor. My car beeps when reversing, what about yours?
Cheers!
Old Nov 14, 2005 | 07:59 AM
Gazzz's Avatar
I just made some promotional banners for Honda (Melbourne)
They are planning a large promotion of their new 'pro' oil range... wether this includes auto i'm not sure... but just thought i'd put it out there.
Old Nov 14, 2005 | 09:53 PM
vtec's Avatar
Thanks Gazzz
Old Dec 19, 2005 | 11:59 PM
icejazz's Avatar
Vividjazz,
any idea how I could get the new CVTF oild in Melbourne?
cheers.
Old Dec 24, 2005 | 02:03 AM
Kirsty's Avatar
Hello Thanks for putting this on the forum as I have just imported a hot black fit which from Japan which has done 33,000 ks and it vibrates too!! After reading the above you have helped me out too. I will do what you have done above to try and fix mine. I live in New Zealand, Auckland. Thanks
Old Dec 25, 2005 | 05:53 AM
discoburg's Avatar
Originally Posted by vtec
Hi,
Thanks.
Quite a few Fit/Jazz owners in Singapore had solved that vibration problem with the CVTF change. It will be good to change every 30-40K
Old Dec 27, 2005 | 05:56 AM
surya's Avatar
Hi,
Cheers!
vtec, u must change ur transmission fluid with the CVTF if u use ATF-Z1 after 10k-20k ur transmission start to vibrate again coz mine do.
Old Dec 28, 2005 | 10:16 PM
vtec's Avatar
surya,
I would if I could. We cant get CVTF!!! I will just have to change it every 10k-20k until Honda start importing it.
vtec.
Old Dec 29, 2005 | 03:37 PM
Kirsty's Avatar
Hi - I have just changed my Trans fluid with CVTF fluid from Honda, Auckland. It cost me $19.95 for 1Ltr and I ended up using 4 Ltrs. This CVT fluid has only just come out on the market for the CVT's. After changing the fluid I jumped in the car and took her for a spin and she's fixed!! Thanks everyone for your help in this matter!!
Old Jan 14, 2006 | 10:48 AM
epin's Avatar
Hi There!
Seems like have the same problem like me.. when i change from NETRAL to DRIVE, it will produce vibrations like the wheel's spin off from the road. Why is this happend?? HELP ME!!
Old Jan 14, 2006 | 09:01 PM
vividjazz's Avatar
Originally Posted by epin
Hi There!
When you change fron N to D is the cars brakes fully applied and not released until the gear has been fully engaged?
What milage have you done and have you changed the transmission fluid during the life of the vehicle and if so did you use only the genuine Honda fluid as specified? If you bought the car 2nd hand did you drop all fluids prior to use?
Old Jan 15, 2006 | 06:02 AM
epin's Avatar
[QUOTE=vividjazz]When you change fron N to D is the cars brakes fully applied and not released until the gear has been fully engaged?
Just like this..
E.g. when i'm on the traffic jam, an the transmission is positioned on D, and starts moving slowly (that's the automatic transmission). when i hit the accell. pedal appr. 1/2 (no brakes was engaged), the sound and small vibrations from my steering comes out.. just like the wheel-spin or something.
i hv bring my aria to local honda's dealer, but they said, nothing is happened. that makes me scared.
Mileage is 18.263 km's. I'm the 1st hand. i've changed the honda's CVTF on around 15.000 Km's...
Old May 30, 2006 | 03:40 AM
pating's Avatar
Yup, have it checked at the dealer. changing the right grade of CVT fluid/oil should solve the problem. it happened on my 1.3cvt before 40,000kms.
pating's Avatar
