CVT vibration - help?
Old Jun 9, 2006 | 05:43 PM
gimme's Avatar
Master FitFreaker
I have this problem in my 5sp man Sport
Old Jan 20, 2008 | 03:12 AM
akrams's Avatar
hi im having the same problem-a judder when starting off and no judder on a cold start. so i took it to the dealer and they changed the ATF Fluid with HONDA CVTF- white bottle with red and black letterings. the juddering reduced but when climbing a hill or a slope the juddering comes back.. the dealers say its the start up clutch and i have to replace the entire tranny.. any ideas please???
Old Dec 15, 2008 | 08:21 PM
pating's Avatar
akrams,
its the most cost-effective way to fix the car as far as the servicing dealer is concerned since the cost of the tranny will be borne by the owner. as for you, the owner, try driving the car conservatively to see if the start clutch will wear out evenly until the vibration goes away.
Old Oct 12, 2009 | 12:57 AM
unclepowers's Avatar
Originally Posted by vtec
Hi,
I have just got my Jazz/Fit, and have noticed a vibration when moving off from a dead stop. It doesnt do it when the engine is cold, first thing in the morning.
I have read on the net that it may be the CVT fluid being ATF-Z1, and it should be changed to Honda CVTF. Or it may be a problem with the 'start up clutch', whatever that is. Has anyone had this problem, or has heard of it?
Thanks.
2002 Fit 1.5 Vtec CVT (Vivid Blue)
Both the Civic and Fit CVTs suffer from what is know as transmission shudder from time to time.Its nothing the right transmission oil and filter change can't solve.
Old Dec 24, 2009 | 03:43 PM
mercator's Avatar
For sometimes you could change control block CVT or you could clean it by yourself if think you can do it,a can share fotomanual.
Old Nov 14, 2015 | 05:13 AM
Puneet_9's Avatar
Hey Kristy, I live in auckland as well .. Can you please tell me from where did you get your vibration fixed .. i need for my car as well. thanks
Old Jan 7, 2016 | 09:10 PM
nigel_nz's Avatar
I'm based in Wellington NZ, I used to have a shuddering CVT transmission too. I had my CVT flushed and used only original Honda fluids, this solved the problem. There is a thread in this forum if you wish to DIY. I did mine by myself and had no issues.
A friend of mine (fit owner as well) recommended that I use Xado EX120, an additive designed for CVT transmissions. I tried it and I have not encountered any issues ever since.
ROTORHEAD77
Aug 2, 2012 03:13 PM
pedgyboy
Jul 14, 2011 10:41 PM
kris bali
Mar 23, 2011 10:09 AM
gmbdelsol
Mar 22, 2010 06:02 AM
shaolin
Oct 23, 2005 11:35 AM
