I put in a BAD BOY™ AIR HORN
Old Oct 5, 2008 | 10:22 PM
pinballlooking's Avatar
http://www.harborfreight.com/bad-boy...orn-94117.html
This is a major improvement. I did not know it has a separate horn for when you lock the doors. This is very nice it does not sound the air horn when you lock the doors. This horn is loud but that is how a horn should be.
(You need to install a relay with this horn)
It pulls much more power than the stock horn and circuit was designed for.
Old Oct 5, 2008 | 10:26 PM
barams's Avatar
does it amplify the existing horn or give it a different sound.
was thinking of getting a new horn. existing one sounds wimpy. i do use my horn on the bad drivers out there.
Old Oct 5, 2008 | 10:34 PM
It has it own sound.
This link will play the sound BE CAREFUL very LOUD!!!
http://www.autobarn.com/images/miva/...ounds/419a.wav
details
small only 2-1/2" W x 4-1/2" L x 4-1/2" H
"2x louder than factory horns
This "bad boy" gets everybody's attention. Dual tone air horn is twice as loud as your factory horn.
  • Easy installation, uses existing factory wiring
  • All-in-one design, no separate compressor or hoses
  • 118 dB, 530/680 Hz
  • Compact unit works with any car, truck, motorcycle or boat with a 12V system "
Not for everybody I am sure.
Old Oct 5, 2008 | 10:53 PM
Pepperinyoureye's Avatar
That has to be the most annoying sound in the world.
Old Oct 5, 2008 | 10:59 PM
It is loud you will not be ignored with this horn.
Old Oct 5, 2008 | 11:16 PM
barams's Avatar
annoying but very cool. i hope you use this often.
Old Oct 5, 2008 | 11:25 PM
enjoito's Avatar
fail... should of put the train horn ftw
Old Oct 5, 2008 | 11:31 PM
mole177's Avatar
meh.. not my type of horn...
but it is attention getting.
Old Oct 5, 2008 | 11:36 PM
dank24's Avatar
Its different. Not something I would do though.
Old Oct 5, 2008 | 11:48 PM
BlueCell's Avatar
My friend put one of these in his Fit, It's deafening!
Old Oct 6, 2008 | 12:32 PM
misfit83's Avatar
Oh man I love loud horns.... was it easy to install?
When I had my Ranger I got passed by another lowrider.... he had one of those or a train horn (not sure ... we were going 70+). Crazy stuff.
Old Oct 6, 2008 | 12:53 PM
FitStir's Avatar
Question
Is it a deep tone?
I really wanna get a loud deep trucker horn on my Fit, but still keep the original for use when needed.
Old Oct 6, 2008 | 01:57 PM
BlueCell's Avatar
Not sure how the Bad Boy sounds, but the one I pictured is not as deep as a Trucker's horn. You would need a bigger Horn and a larger compressor for those. The smaller one is actually louder because you don't need as much air to power it.
Old Oct 6, 2008 | 02:50 PM
FitStir's Avatar
Thanks. I gotta check that sound clip later.
It's good to use when people blindly cut in front of me, or are oblivious to their surroundings. Its a good wake up call.
Old Oct 6, 2008 | 04:33 PM
r90s's Avatar
Wink I've used these...
I have used the compact horns from this company, on motorcycles, they worked very well.
http://www.fiammamerica.com/HornsIntro.asp
A Better Link, for a look...
http://www.fiamm.com/product/product.aspx?catid=0.13
Old Oct 6, 2008 | 04:52 PM
One bolt then move the + wire from the original horn and I had to add a wire to a bolt for ground. The horn I replaced was right by the hood latch. It did not take that long to do.
Old Sep 6, 2011 | 06:28 PM
kcbates85's Avatar
these bad boys may just be my first mod, then tint and then retrofit/projector headlamps HID 6ks with matching fogs
Old Sep 6, 2011 | 07:13 PM
fawbusha's Avatar
That's pretty sweet man
Old Sep 7, 2011 | 07:17 AM
SilverbulletCSVT's Avatar
I strongly suggest you disconnect that horn asap and install a relay before using it again. It pulls much more juice than the stock horn and circuit was designed for. With enough use it can fry your stock wiring and horn switch. It should have come with a relay in the package.
_
FitStir
Sep 3, 2012 12:07 AM
pedaler
Sep 14, 2011 05:23 PM
HaulSmall
Mar 31, 2011 06:33 AM
gummyrabbit
Nov 23, 2007 03:30 PM
mute
Apr 1, 2007 10:53 AM
