Micro Fuses???
Old Oct 20, 2008 | 09:03 PM
neteng101's Avatar
Micro Fuses???
I blew one of the small fuses today in the accessory slot and what I found is a type of automotive fuse I've never seen before. Its the mini blade type fuse only this time there's no blade, the blade is part of the housing.
Where is one to find a replacement fuse?
Old Oct 20, 2008 | 09:18 PM
Virtual's Avatar
Autoparts store?
Old Oct 20, 2008 | 09:22 PM
Goodguy-Fly's Avatar
Originally Posted by Virtual
Autoparts store?
Not very often are you going to find a proprietary fuse, the parts store will have them.
pinballlooking's Avatar
I got some at Auto Zone over the weekend.
Old Oct 20, 2008 | 09:25 PM
bobbied's Avatar
Pepboys has them, just look around the fuse section.
Old Oct 20, 2008 | 09:27 PM
CRXsi#32's Avatar
normal mini fuses will work also...they look slightly different but they do fit and work.
Old Oct 20, 2008 | 09:49 PM
neteng101's Avatar
Phew - good thing to know they're readily available. I haven't seen this style before - I have spares of minis and used one of those for now. Not a perfect fit but it works till I can get to Pep Boys or Autozone.
Old Oct 20, 2008 | 09:55 PM
CRXsi#32's Avatar
Why do you say it's not a perfect fit? Is it just because it sits taller than the others? To the best of my knowledge the metal contacts are the same distance as the newer style fuse...just the height of the plastic part is taller....
Old Oct 20, 2008 | 09:57 PM
neteng101's Avatar
Yes just taller than the rest - its functionally fine though.
Old Oct 20, 2008 | 10:06 PM
CRXsi#32's Avatar
I wouldn't be in a panic to replace it then. Even many dealers use the old style fuses as replacements. If it bothers you can get the new style but it shouldn't affect the functionality.
Old Oct 20, 2008 | 10:14 PM
neteng101's Avatar
I'll admit I'm a nut about fuses (thus why I had spares of minis)... but knowing the mini ones work is helpful. I'm going to look for a selection of the new style to keep as spares.
Old Oct 20, 2008 | 10:27 PM
IfTheFoo's Avatar
Aren't there a few spares in the fusebox?
Whatcha running off the acc fuse that would cause it to blow? Hairdryer? ;-)
Old Oct 20, 2008 | 10:35 PM
neteng101's Avatar
I couldn't find any spares in the fuse box. It was my portable air compressor that did the fuse in... I was having a hard time getting air into one particular tire with the bigger compressor, I think I need to get a new air chuck for it.
Old Oct 21, 2008 | 11:28 PM
neteng101's Avatar
So I went looking today - and they are hard to find around here. Pep Boys - nada... Strauss Discount Auto... nope... Autozone... score (only 2 packs of assorted low profile ATM fuses there, I bagged them).
Old Oct 21, 2008 | 11:56 PM
CBX's Avatar
CBX
I found some at Checker Auto. The assortment included the values used in the Fit.
Old Oct 22, 2008 | 12:15 AM
IfTheFoo's Avatar
Suprised to hear there there no spares.. I guess I'll be buying some online or local..
Old Oct 22, 2008 | 12:55 AM
CBX's Avatar
CBX
Yeah, I had studied the fuse diagram in the owner's manual pretty thouroughly to detemine there were no spares. I was on my way to Mexico, so I figured I better get them, pronto!
If one happened to blow, I'm sure you could swap out another non-essential one, such as a power-window fuse. The power port (formerly known as cigar lighter) circuit requires a 20A fuse.
Miranda Spoox McHenry
Nov 18, 2016 04:54 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
over40pirate
Jun 7, 2014 08:35 PM
fad3r
Jan 27, 2013 04:04 PM
