Vibrating clutch pedal anyone?
Old Oct 29, 2008 | 05:19 PM
CrystalFiveMT's Avatar
My clutch started to exhibit some kind of grinding feeling as I let up the clutch, mostly when the car is cold and releasing the clutch on 1st and 2nd.
I experienced this on my 08 Accord though on the Accord is was quite a bit more noticeable.
It just started about a week or so ago and got worse almost overnight. I hope it doesn't get any worse as I don't find it too annoying right now.
Just wondering what it is and if there's a fix. I think it may be the springy mechanism between the clutch and tranny.
Old Oct 29, 2008 | 06:47 PM
Firebat666's Avatar
that sounds very not normal... id bring it in...
Old Oct 29, 2008 | 07:43 PM
It's definitely not normal since it wasn't there until a week or so ago. I have 3600 miles currently. My 08 Accord had the same thing only more pronounced and when I took it to the dealer they said it was normal. Figures.
Old Oct 29, 2008 | 07:49 PM
Firebat666's Avatar
i get start up chatter on the clutch when i dont give it enough gas... but never while shifting... what rev are you shifting at?
Old Oct 29, 2008 | 07:54 PM
JDMxGE8's Avatar
Check your CMC?
Old Oct 29, 2008 | 09:44 PM
What's CMC?
I'm shifting at normal around town speeds. I feel it no matter what. If it's not engaging in a gear it won't do it. If the engine is off and you let up on the clutch it won't do it. If the engine is on and you're in neutral and you let up on the clutch it won't do it.
I pretty much only notice it going into 1st or 2nd, but more in 1st.
Old Oct 29, 2008 | 09:47 PM
Fit4Pits's Avatar
did it just get cold where you live this past week?
Old Oct 29, 2008 | 10:07 PM
Masterdebater's Avatar
im guessing hes meaning clutch master cylinder? or a cow milking cat?
Old Oct 29, 2008 | 11:17 PM
ak_honda's Avatar
check fluid level in the clutch master cylinder... shouldn't be leaking but if it is then definitely bring it to the dealership. i've had mine actually run dry =p don't ask.. it has a slow leak apparently in my accord
Old Oct 30, 2008 | 12:29 AM
Temps are still summer like here, that's not it. Has nothing to do with temp. as my Accord had it through a few seasons.
Where is the clutch master cyl fluid?
CrystalFiveMT
Aug 13, 2016 02:56 PM
SammiJo
Jul 25, 2012 06:59 PM
Previc93
Sep 8, 2009 11:14 AM
shy34
Aug 31, 2009 03:16 PM
CrystalFiveMT
Oct 31, 2008 01:02 PM
