HKS Turbo Kit Install Manual
Old Nov 2, 2008 | 03:29 AM
Spooling's Avatar
http://members.shaw.ca/fitfreakhks/h...tGD3Manual.zip
Old Nov 2, 2008 | 10:30 AM
Nabisco's Avatar
Senior Member
Thank you.
Old Nov 2, 2008 | 10:37 AM
rvall004's Avatar
thanks dude!!
Old Nov 2, 2008 | 03:01 PM
explosivpotato's Avatar
Wow, that's a way better instruction manual than I got with the T1R kit..
My instructions told me to remove the passenger side axle.. not sure why, though. I just dropped the turbo in from the top. Never touched the axle.
Old Nov 8, 2008 | 11:46 PM
bdk323's Avatar
I was looking at the install manual and I noticed it has you connect a portion of the F-CON to the odb2 port so am I to assume this mean you loose your scangauge if you have one and is there a way to have both connected if this is the case Thanks
Old Nov 8, 2008 | 11:52 PM
bdk323's Avatar
I should have looked before I asked but anyway I did a quick google search and found a odb2 Y cable to install two devices my guess is thats whats has to happen
Old Nov 9, 2008 | 02:03 AM
joquio's Avatar
Thanks for sharing.
The only thing that's holding me back from this Kit is the lack of tuners for the F-con locally.
Do you know anyone who can tune this? Where you gonna get it tuned? Or just using the factory tune?
Old Nov 9, 2008 | 02:04 AM
joquio's Avatar
Oh by the way, mind to share where you got this kit from and for how much?
Old Nov 9, 2008 | 02:35 AM
Spooling's Avatar
Originally Posted by joquio
Thanks for sharing.
There are F-Con tuners in Vancouver, Non of them are certified. They tune the VPro mostly... but can tune the IS when asked. For me, I'm stripping out the Fcon once I get the hang of the stock map. Then I'll drop in the E-manage ultimate.
Old Nov 9, 2008 | 03:27 AM
joquio's Avatar
wow...........sounds complicated........lol
Good luck with your build!
Old Jan 24, 2009 | 06:29 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
where and for how much IS VERY USEFUL
Old Feb 12, 2009 | 03:16 PM
trinisir's Avatar
Hey. Well I can't afford to ship this HKS kit all the way down here... but; I can surely try to make up the kit myself. Can any one post the actual measurements of the piping pieces, and the bend angles? Please...if that is possible. The manual download is a really BIG help, if I had the actual pipe measurements, that would be a REALLY big help.
Old Feb 12, 2009 | 04:17 PM
NIGHTHAWKSI's Avatar
^your going to have a MUCH more difficult time getting some one to measure the pipes exactly for you...there are some areas that it is a very tight fit. and if you did get them, theres a good chance that you might mess up 1 measurement along the way which would suck.
your better off jsut designing piping from scratch. it will be much easier...just use the HKS/T1r pipe layout as a guide.
also, if i read that manual correctly...for a turbo drain line it runs a banjo fitting (bad), to the oil drain bolt (bad) below the oil line(horrible). if that is correct, im suprised peoples cars with this turbo kit have lasted this long.
Old May 9, 2011 | 07:16 PM
GatorFit24's Avatar
Just buy my kit and half of shipping and you will have the HKS kit with piping
Old Nov 27, 2012 | 09:15 PM
ELMUES's Avatar
i cant see the manual
Old Jun 30, 2015 | 04:30 PM
guailifit's Avatar
I Know this thread is very old but anyone here have this Install Manual
Old Aug 3, 2015 | 04:17 PM
eightsixlife's Avatar
Same here, if someone could please share, TIA!
Old Jan 1, 2017 | 09:36 PM
lukusis's Avatar
Necro-bump, I know.
But, any chance someone out there has a copy of the install manual?
Ta
Old Jul 25, 2017 | 01:00 PM
sleepingAwake's Avatar
Im a few months late but ask and you shall receive.
https://drive.google.com/file/d/0B18...w?usp=drivesdk
andykin29
Sep 24, 2011 02:41 AM
GatorFit24
15
Aug 19, 2011 10:18 AM
savior
Sep 2, 2010 10:36 PM
LaoSiFu
Jun 18, 2010 08:11 AM
southwilrise87
May 8, 2006 12:14 AM
