Wiring Diagram "want to add some mods"
Old Nov 2, 2008 | 10:03 AM
struct32's Avatar
Post Wiring Diagram "want to add some mods"
Taking delivery of a 2009 Fit Sport in about 3 weeks.
A couple of mods planned:
- Hardwire power for Sirius Plug-n-Play unit: Where can I locate accessory wire under the driver side (near column or fuse box)?
- Want to add 2 additional "accessory sockets" (what was Honda thinking with only 1?): Should I go with an "accessory" wire for this or any suggestions at the fuse box? I want these additional sockets to only work with the key turned to accessory?
I am very hand with car audio, so I'm just looking for a Sherpa to lead me in the right direction.
Much love for the forum -- struct32
Old Nov 3, 2008 | 11:29 AM
colicab119's Avatar
If you are adding two accessory plugs I'd make one constant and one ignition controlled. For an easy install go to the fuse box, for a clean install go to the column or behind the stereo. Just be sure to instal an in-line fuse to protect the circuit
Old Nov 3, 2008 | 11:46 AM
struct32's Avatar
2009 Fit Sport Wiring Diagram "want to add some mods"
Thanks colicab119,
But, I'm also looking for info on what color wire is "ignition/acessory" at the column? At the fuse block I assume I can use an open position and tap into said position on the back side of the block, correct?
Thanks, Struct
Old Jan 3, 2009 | 12:09 PM
runbikerun's Avatar
Has anyone found what wire this would be?
Old Jan 3, 2009 | 12:12 PM
binaryh4x's Avatar
If you are near the fuse box, I would try a fused fuse tap. Just plug it into an already switched fuse.
Foots
May 19, 2012 05:29 PM
MarcoM
Jan 5, 2011 08:23 PM
stock0891
Feb 20, 2010 04:06 AM
TWGE08
Jun 10, 2009 07:54 PM
vwli
Jun 8, 2009 03:38 PM
