hid problem
Old Nov 8, 2008 | 03:06 AM
enjoito's Avatar
hid problem
installed my hid kit today when i turn it on it indicates the high beam is on. and i'm not in high beam. i tried to re-pin it and same thing.
the hid kit has a holagen bulb on the side didnt come with a relay.
dunno what to do the high beam light gets to me. high beam doesnt work 2.
Old Nov 8, 2008 | 03:12 AM
kylerwho's Avatar
spoon fed
when you tun the high beams on do the lights shut off?
Old Nov 8, 2008 | 01:11 PM
xonexlifex's Avatar
do you have drl's or driving lights on ur fit? bec in different parts of the world some fits have driving lights and if you do you need to somehow disconnect them to run hids on ur fit, i had the same problem with putting on an hid high beam kit on my friends 2000 chevy silverado, since he has two bulbs it only messes up if you put a hid kit in the high beams, but since the fit usually only has one bulb for highs and lows than it wont work unless you disconnect the driving lights from your car, ive seen this alot of the canda fits, check around on the forum and see if you can find a fit that had to disconnect them, only if you have driving lights on ur car
Old Nov 8, 2008 | 01:21 PM
enjoito's Avatar
i have a gd i know there is no day time running like or is there. the fits here are the same fits u guys have in the mainland so i dunno whats goin onn i think i'll sell my hid kit and get a bixenon one
Old Nov 9, 2008 | 02:14 PM
xonexlifex's Avatar
you can do that or just ask them what could be wronge with it, i had a hid kit that i had problems with on a another car and i contacted the place i got them from and they fixed the problem for me, id just shoot them a email or phone and see if they can help before you send them back
Old Nov 12, 2008 | 02:03 AM
enjoito's Avatar
they said some cars have no problem i asked if they can send me a relay and no answer. so i think i'll remove it and buy another kit.
Old Nov 12, 2008 | 02:06 AM
koolkevin1107's Avatar
no don't return it. U probably have the pins in the wrong place. I highly recommend u just re-pin it on both sides. U'll figure it out. Remember, there is ONE positive and TWO grounds in the oem harness.
Old Nov 12, 2008 | 02:07 AM
Will I Am fit.'s Avatar
Formerly "bitoy"
try switching the three prongs that connect to your stock harness thats mostly the case.
Old Nov 12, 2008 | 02:22 AM
enjoito's Avatar
i tried doin that i went in all ways.. still the high beam indicator is on. and high beam wont work.
it did it on my civic so i left it.
im just afraid of frying my wires.
airwicc
Oct 30, 2010 11:09 PM
stnl619
Dec 24, 2009 12:40 PM
erichyung
Mar 22, 2009 01:20 AM
FITtin'
Dec 9, 2008 04:29 PM
stockfitgd3
Dec 8, 2008 01:12 PM
