still rubbing. what else can i do?
Old Nov 9, 2008 | 04:02 PM
revd34's Avatar
i rolled my fenders and shaved down the bracket for the screw where the bumper mounts. the problem is that it is still rubbing. it is hitting that stupid screw and maybe just a little of that bracket. what else can i do?
btw i'm running 15x7 +35 with 205/50/15 tires and lowered on eibach sportlines. i like the offset so don't suggest to me changing it
Old Nov 9, 2008 | 04:45 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Remove the screw, bend/smash it flat. Drill holes in the bumper and use zipties to hold the bumper in place.
If it rubs after that, turn the radio up.
Old Nov 9, 2008 | 05:59 PM
Fit4Trav's Avatar
get a different tire size 205 is too wide for 15x7. Switch to 195/50 or even 195/45. I am running the 45 series and am dropped about 2" with HKS coilovers on 15x7 +13. I can still/should lower my car another .75" (estimate on the low side) and I don't rub @ all now.
Old Nov 9, 2008 | 06:16 PM
revd34's Avatar
lol sounds great. zipties? that actually sounds like an ok idea
i was thinking 195/50. so you don't rub at all? cuz my springs give about the same drop. it looks like i might have to get new tires.
Old Nov 9, 2008 | 06:19 PM
fitoromocto's Avatar
take that screw out grind that bracket it work for me, tie wrap or lock wire. the hole you drill will be smaller if you used lock wire
Old Nov 9, 2008 | 06:48 PM
Posts in the NUUDE
Dont get 195/45's on a wheel with +35mm. It wont look good unless youre going to drop it to the ground.
195/50's are best.
I think 205/50's are fine. Just remove what rubbing.
Old Nov 9, 2008 | 08:54 PM
mahout's Avatar
Then live with it. You could get 195/50x15's perhaps but with that extreme offset I doubt that will work either.
Or 195/45x15 if they make them.
Old Nov 9, 2008 | 10:20 PM
Fit4Trav's Avatar
^^Extreme offset??? +35 that's conservative...
195/50's are best.
This is true.
BTW what springs are you running that gives you a 2.5" drop?? Man I must be alot lower than what i said if you have springs that give you that much.
Old Nov 10, 2008 | 04:09 AM
revd34's Avatar
This is true.
i'm running eibach sportlines. it actually give a 2 inch drop not 2.5
Old Nov 10, 2008 | 04:13 AM
revd34's Avatar
i don't gave to live it. people run the same offset without rubbing. fit4trav is running a +13 offset. that is a lot more extreme then my offset.
thank you all of you for your advice
Old Nov 10, 2008 | 08:24 AM
mahout's Avatar
Any time you move the centerline of a wheel at least 3/4" out the dynamics of the suspension begin to look bad. All suspensions are designed to intersect the 'kingpin' angle with the tire centerline at the bottm of the tire. Deviate very much and handling goes very wrong.
On any Fit we've had in here you can't even get 40 mm offset to work with stock height and OEM tires/wheels without considerable body modification.
Old Nov 10, 2008 | 09:05 PM
whtsjdm's Avatar
......lolwut
Old Nov 11, 2008 | 07:38 AM
User Name's Avatar
on any fit we've had in here you can't even get 40 mm offset to work with stock height and oem tires/wheels without considerable body modification.
omg........
Old Nov 12, 2008 | 02:46 AM
revd34's Avatar
no more rubbing. i am so happy thanks
Old Nov 12, 2008 | 03:07 PM
Fit4Trav's Avatar
What did you do to fix it?
SBT
Jan 18, 2012 03:43 AM
roflmayorga
Jun 4, 2010 04:59 PM
FLFIT239
Jul 6, 2009 01:36 PM
kancerr
Sep 16, 2008 03:15 PM
08FitSport
Jul 20, 2008 08:41 PM
