stock h mod.
Old Nov 12, 2008 | 02:21 AM
enjoito's Avatar
stock h mod.
i wanna remove my red h's and put the stock ones back on.
the front i think i have to buy a new grill??
the rear how would you instal the stock h back on there.
Old Nov 12, 2008 | 03:27 PM
Fit4Trav's Avatar
3m tape I am assuming? no clips right?
Old Nov 12, 2008 | 04:40 PM
koolkevin1107's Avatar
oh man removing that rear type-r H is gonna b hard. I think the best way to do it is to go get some GOO GONE and just pour it behind the emblem while using a credit card or similar prying object to lift it up. The goo gone will dissolve the adhesive. U can always put new adhesive on there later. To put the rear H back on, use the GOOD 3m double sided tape. U can buy it from Osh or home depot. It's the HEAVY DUTY one with the RED backing... don't get the checkered one that's weak. Then just put it on the areas that are recessed on the back of the emblem.
For the front, if you shaved down the original points of the oem grill, that means u'd have 2 get a new grill so it doesn't show imperfections. Mounting it is the same way, with 3m tape.
Old Nov 13, 2008 | 05:46 PM
Tofuman's Avatar
it might even be a better idea to trade the rear pannel with someone who has the stock emblem on the same color car you have. i'm sure a lot of people would trade for the rear pannel with the red h attached.
Old Dec 8, 2008 | 04:02 AM
feared's Avatar
i'll trade you if you have ssm
Old Dec 8, 2008 | 11:12 AM
TurboManGT's Avatar
Honestly for the rear I would get a new emblem with the pegs. I think its like $10-20. That is the route I would go.
Old Dec 8, 2008 | 01:29 PM
ghibli99's Avatar
Yep, same here. For the rear, just use some fishing line to cut the rear emblem away, get as much of the adhesive off as possible (a heatgun helps), and Goo Gone the rest, buy a new pegged OEM emblem and there you go.
-Mike
beangrower
Feb 4, 2011 11:54 PM
AnlDyxp_GD3
Mar 24, 2010 12:59 AM
mcy
Apr 1, 2009 06:47 AM
GD3xFit
Mar 3, 2008 06:07 PM
