K20 Fit 2nd Generation How To Discussion
it does sit more under the dash/towards the fire wall and under the plastic trim at the bottom of the windshield. Some of the manifold is covered by the plastic trim at the bottom of the windshield as well.
i think it will be a really difficult swap. the k is taller than the l series so i think height clearance will be a problem too because you have a window to deal with instead of just raising the hood.
yeah its like a few fingers space between the top of the mani and the window trim
i think the k20 has a good couple inches height on the l15 but you can also customize the cross member and mounting locations too accomodate for the size. i would just wait for j's or someone on kswap.org to do it.
