Triple DIN Gauge Pod in 07 Fit Dash Kit?
Old Nov 25, 2008 | 06:21 PM
YeeFit's Avatar
I'm looking to install a triple 52mm DIN gauge plate in my Fit. But before I order it, does anyone know if it will fit along with a single DIN head unit?
Universal Triple Gauge Single Din Radio Face Pod
I guess the big question is has anyone used one of these before and is the 07-08 Honda Fit dash kit from scoche a true double DIN?
I already have the T1R 60mm gauge pod and it holds my boost, water temp, and oil temp gauges. But I now have a 52mm AEM UEGO that I am trying to find a home for and the most logical way without drilling or cutting my dash is to go with this option. I am thinking of filling up the other 2 openings with the 52mm matching versions of my 60mm gauges. But I'll use oil press and maybe voltage to complete the package.
Old Nov 25, 2008 | 11:52 PM
koolkevin1107's Avatar
Well i would assume so because the fit does use a standard double din slot and since that is only 1 din slot thick, i wouldn't see why not.
Old Nov 26, 2008 | 12:32 AM
dewthedew's Avatar
only works with a sweet yellow dash
Old Nov 26, 2008 | 12:42 AM
YeeFit's Avatar
I don't think it will fit... i just tried to place an alpine deck in the kit and then my 52mm gauge below it and there isn't enough space.. I measured the total space available after a deck is installed to be 2". This DIN piece measures 2-3/8" as mentioned in their website..
Old Jan 27, 2009 | 03:11 PM
YeeFit's Avatar
Well, I took a chance and ordered up the triple DIN gauge plate. It does fit with a deck but it will need a little modification to the dash kit.
I've got mine ready to go, only 1 gauge tho (can't decide on the other 2 to get). Once I get it installed I'll post a pic to show everyone!
Old May 2, 2011 | 11:21 PM
GatorFit24's Avatar
Cant wait to see the pic.. I am in the same situation as I am trying to find a place for my gauges
Old May 2, 2011 | 11:34 PM
GatorFit24's Avatar
well i just ordered the same gauge pod.. If you could tell me what modifications u did so it will fit, I would appreciate it a lot
Old Jun 6, 2011 | 04:40 AM
GatorFit24's Avatar
I have no idea what modifications u did to make it fit, but it doesn't fit under my radio so i left it alone and went a different route
Old Nov 24, 2011 | 12:43 AM
CharlotteGE8Alex's Avatar
i have it already three gauge in single din with a single din flip out 8.3 inch screen
Old Sep 3, 2020 | 07:09 PM
dll932's Avatar
just a thought: an enclosure could be made that sits atop the dash center.. It could be made of thin plywood and covered with vinyl.
headrec
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Dec 17, 2018 03:25 PM
GD3_JDMLIFE
Aug 12, 2012 07:24 PM
daveyamo
Mar 2, 2011 01:05 AM
YeeFit
Nov 1, 2010 09:48 PM
Pepperinyoureye
Jul 17, 2008 05:08 PM
