HID's on the fit
Old Dec 6, 2008 | 07:59 PM
iheartJDM's Avatar
HID's on the fit
Hi, im kind of a noob for the fits and im curious as to the bulb pattern of them. The HID kit off of my EK will plug up as an H4 but for some reason only the high beams work. i have a Hi/Lo kit. Any information is very much appreciated. Thanks in advance
Old Dec 6, 2008 | 10:12 PM
fitster's Avatar
u most likely have to move the power prong to the empty socket on your h4 plug
thats what i had to so with my kit also
Old Dec 6, 2008 | 11:06 PM
Arisenfury's Avatar
The simple solution would be to not add HIDs to a car that wasn't designed for them.
Old Dec 7, 2008 | 12:38 PM
TurboManGT's Avatar
Where is the fun in that?
Old Dec 7, 2008 | 02:09 PM
xonexlifex's Avatar
exactly, id rather be able to see more!
Old Dec 7, 2008 | 03:00 PM
Rubba Burna's Avatar
HID Addict
i didnt use a kit, but it is HID, just a bulb. honestly i think its a good deal compared a kit, 40 bucks for all lights with that brightness, heh, hell of a money saver. heres a pic of the output, 7000k. any car is deisgned for bulbs.. right?
the yellow light is close to 4000k, its an outdoors overhead light
Old Dec 7, 2008 | 05:28 PM
iheartJDM's Avatar
well im not really worried about spending the money and considering i already have a kit its no big deal. A lot of cars that have HID's installed are cars that weren't "meant" to have them.. i believe thats the reason they made aftermarket ones correct? i prefer my HID's over the stock bulbs anyday... just wish i could get them to work right
Old Dec 7, 2008 | 05:37 PM
azncarbos's Avatar
are these HID Low and Halogen Hi? If so.....check the wire!!! there should be a red wire, a two black wire with one connection and one black wire....
Old Dec 7, 2008 | 05:51 PM
Rod2Rice's Avatar
HIDs in any car that did not originally come with them is technically illegal, just keep that in mind. The kits were made for the manufacturers to make money, thats all!
Old Dec 7, 2008 | 06:29 PM
Arisenfury's Avatar
I think he has the "HID" bulbs from ebay that are just high powered halogens with a blue coating. Chances are if the High Beams aren't working with that then the bulb is messed up, either that or the high power fried the wire to the high beam.
Old Dec 7, 2008 | 08:19 PM
iheartJDM's Avatar
i have an actual kit. Ballast/bulbs etc. and yes that is correct about the halogen high and HID low. and yes i know they are technically "illegal" but so is my limo tint/ license plate cover/ and me rockin no front plate. The area i live in isnt really strict on little things like that... unless you get pulled over then they like to add it on to the tickets or whatever.. Southeast Texas is easy to get away with things.
Old Dec 7, 2008 | 08:26 PM
iheartJDM's Avatar
i have seen a couple types of kits..
the ones where you have to put a hot wire to your battery
or the one like i have.. it plugs into your oem light harness which runs the ballast no hot wire to the battery needed. it just plugs and plays with the oem harness. i know one of the prongs is for the highs and the other is for the lows (i had to rewire one of my old hatches because the harness for the light was damaged during a engine swap) and the top prong i believe is the ground.
the high beams worked when i plugged it up, but the lows didnt click over
(ballast didnt turn on) i tried both ballast with the same result
Old Dec 8, 2008 | 02:38 AM
azncarbos's Avatar
red go on top and the black with two wire on left and one wire on right...if that dose not work switch the black around...hope that help if not Hit me up!
Old Dec 8, 2008 | 02:51 AM
enjoito's Avatar
hid its a must on any car its like almost 2009 hid should be on every car already stock bulbs are crap cant see good.
Old Dec 8, 2008 | 10:57 AM
TurboManGT's Avatar
I agree I think all vehicles should be equipped with HID
Connor Keyser
15
May 1, 2016 02:44 AM
orange2007vafit
19
Aug 18, 2012 02:04 PM
m-man@sbcglobal.net
Jan 16, 2010 05:24 PM
Crawly
Aug 22, 2008 09:13 AM
bestfit
Mar 16, 2007 09:49 AM
