I HATE VELCRO!...Blitz TC Install
Old Dec 10, 2008 | 04:30 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs down I HATE VELCRO!...Blitz TC Install
Old Dec 10, 2008 | 04:57 PM
NBPturtle's Avatar
I think when you get the black foam it will look pretty clean!
Old Dec 10, 2008 | 05:00 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 10, 2008 | 05:42 PM
Fitting's Avatar
I mounted my control unit under the driver seat and the controller next to the handbrake with velcro.
I thought of putting the controller where you put it but would didn't want to move it everytime I have to get access to the fuse box.
Old Dec 10, 2008 | 06:26 PM
gimme's Avatar
Master FitFreaker
dude, you have it all wrong. When my wife notices something new, i say "babe, i got that like 4 months ago." and it's over and done with can't argue about something that was done a while ago.
Old Dec 10, 2008 | 06:31 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 10, 2008 | 06:32 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 10, 2008 | 07:08 PM
TurboManGT's Avatar
I hate the thought of velcro too
Old Dec 10, 2008 | 07:34 PM
theloxmyth's Avatar
Fit Gadget Freak
I took my SGII apart to see if I could screw it to the dash, before I found BlendMount for it.
It would have been hell trying to screw the back-cover back on, while the back-cover was screwed to the dashboard.
Old Dec 10, 2008 | 08:37 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 10, 2008 | 09:24 PM
manxman's Avatar
Originally Posted by theloxmyth
I installed the Bitz TC and I decided to put it somewhere she might not notice.
Since I am seemingly the only driver of "my new toy," I decided to mount the Blitz here...
There's just a piece of foam behind it, to keep it stationary for use. I will replace that piece with black foam.
Its raining here so I haven't used it, BUT it works like-a-charm in the garage.
(Edit: I don't really hate Velcro. I hate the sticking it places with the sticky stick stuff. It always comes off in the heat and leaves the sticky behind! Don't ask me how I know ; )
Later,
Hey Craig,
Saying "I hate Velcro" is like saying "I hate shoe laces", or "I hate zippers". Using Velcro to hold your throttle controller in an easy to reach, out of the sun place in your car also makes it easy to hide if you have to leave your car in public for a long time. The Blitz control has no permanent mounting features like screw holes-- it's like they had Velcro in mind when they designed it. What's going to keep your controller from falling out of the "wallet holder" pocket? Velcro would.
Old Dec 10, 2008 | 10:46 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 11, 2008 | 11:22 AM
manxman's Avatar
The wire wraps around the rear of the foam.
The foam is over-sized, and crammed in tightly.
Its a tight 'fit.'
Of course you may be right, with my quick turns and high acceleration rate, it might fall out and dangle there.
Wait! We're taking about a Fit.
To each, his own way.
Initial Post:
I figured that you had some logical reason why "you hate Velcro", and I agree that with most Velcro in the hardware stores, the adhesive doesn't work too well on the Fit interior plastic. Heat makes that even worse. My suggestion- use denatured alcohol as your surface prep, and use ONLY "Industrial Strength" Velcro- they sell it at Ace Hardware stores and all over the Internet.
Old Dec 11, 2008 | 12:05 PM
TurboManGT's Avatar
I'm going with the blendmount too
Old Dec 11, 2008 | 02:00 PM
theloxmyth's Avatar
Fit Gadget Freak
Old Dec 11, 2008 | 05:53 PM
manxman's Avatar
Can I use scotch whiskey, instead?
Yes, but ONLY if it is "Glen Kella Scotch" the "Manx Spirit" from the Isle of Man. You will easily recognize it because it is water clear (cuz it is double distilled). Unfortunately, you won't find it in the U.S. Glen Kella has no U. S. distributor or importer. It's the only Scotch that won't give you a hangover.
Old Jan 4, 2009 | 08:02 AM
theloxmyth's Avatar
Fit Gadget Freak
Talking
Old Jan 4, 2009 | 12:04 PM
manxman's Avatar
Dang! I used velcro to mount my Blitz. (shhhhh)
I figured that you would, but your admission comes as a surprise. Imagining your controller constantly falling out onto your legs was kind of entertaining, though.
Old Jan 4, 2009 | 02:23 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs up
Old Jan 4, 2009 | 08:27 PM
manxman's Avatar
Brother,
That shouldn't shock you. I'm a "semi-honest" loxmyth!
Human as I am, I screw-up.
Wearing one's heart on their sleeve (being open and transparent) seems to open up plenty of peoples' dialog.
Let's be real, and honest, with each other.
I imagine one person's triumph or short-cut could save many much frustration!
Besides, without drilling holes, I couldn't get it to mount in the perfect spot that its in without the velcro.
Craig,
Your trade suggests that you have more than the average amount of problem-solving abilities, and that you don't give up easily. I suggested Velcro in several other Blitz T/C discussions simply because it is the cheapest and easiest solution to mounting the control box. It would be nice if Blitz had designed the box with a few flanged screw holes for mounting, but they didn't.
I'm glad that your problem is solved, and if you had found a better way to do it than using Velcro, I would have kept that in mind to try whenever Blitz makes a T/C that works on my '09 Fit. Have a good year!
Waiz
27
Sep 25, 2024 06:30 PM
Cl329
May 31, 2011 07:12 PM
ACfit
29
Feb 2, 2011 01:26 AM
ghettoboy247
35
Dec 31, 2008 06:42 PM
DrKelso
Nov 22, 2008 12:08 AM
