205/50R15 vs 195/55R15 for 15x7 wheels?
Old Dec 10, 2008 | 04:32 PM
dewthedew's Avatar
What should i get?
Old Dec 10, 2008 | 04:36 PM
davela72's Avatar
The question(s) are: is it lowered and what is the offset on the wheels?
Old Dec 10, 2008 | 05:18 PM
dewthedew's Avatar
wheel info on the web site..
PCD: 4x100
ET: 41
Weight: 9.5lbs.
and yes Im lowered on skunk2 springs.
Old Dec 10, 2008 | 05:25 PM
davela72's Avatar
I would say the 205's would be fine or even 195/50/15 but definitely not the 195/55's.
Old Dec 10, 2008 | 06:10 PM
gimme's Avatar
Master FitFreaker
205's and 195/55's will rub
*edit*
if lowered
Old Dec 10, 2008 | 07:19 PM
SHG_Mike's Avatar
i think you might be confused. the 195/55 and the 205/50 have the same OD, and the 205 would be wider however. So in order of least chance of rubbing...
195/50(speedo 2mph off)
195/55 (stock)
205/50(same speedo)
Old Dec 10, 2008 | 07:41 PM
davela72's Avatar
You're right Mike, I was thinking about it correctly.
Old Dec 10, 2008 | 09:31 PM
dewthedew's Avatar
Those are my two options in size both are the same price. I heard the 205s are better for cornering but you lose some mpg? I dont see why id rub with either of those.
Old Dec 10, 2008 | 09:39 PM
dewthedew's Avatar
Im getting these friday or monday so i need to figure this out before then.
Old Dec 10, 2008 | 10:26 PM
underdog's Avatar
I have 15x7 +40 lowered on tanabe gf's and I had it with the stock tires and now the 205/50's. I almost never rubbed with the 195/55's now I pretty much rub every day going to work with the 205's.(bumpy stretch of road on the way) not enough for me to care but they do rub frequently.
Old Dec 11, 2008 | 12:44 AM
gimme's Avatar
Master FitFreaker
195/55 (stock)
205/50(same speedo)
ummm, 205/50 same speedo as which one? I know which one, just want to make sure you aer thinking what i'm thinking
Old Dec 11, 2008 | 01:16 AM
dewthedew's Avatar
so much confusion in this thread.
Old Dec 11, 2008 | 08:18 AM
SHG_Mike's Avatar
195/55 - 23.44" OD
205/50 - 23.07" OD
195/50 - 22.68" OD
yes the 205 is smaller but the speedo will be half a MPH off,but the spec for the speedo is +- 1mph anyway so it wont be nearly a difference like the 195/50 is
Old Dec 11, 2008 | 09:49 AM
kifu's Avatar
The difference in diameter can change slightly for a given size from tire to tire even with in the same brand and model. Not to mention the diameter will change as the tire wears.
Personally I'd go with a 205/50 because I like the more aggressive look of widers tires.
Old Dec 11, 2008 | 10:17 PM
FitVic's Avatar
yeah i'm going with 205/50 for my 15x7 wheels. 195 looks so puny lol Anyone agree?? If it rubs who cares. Nobody said lifes easy anyway lol
Old Dec 12, 2008 | 12:22 AM
dewthedew's Avatar
okay so im getting the 205s. would a scangauge show the correct mph?i dont realy care if its off 2mph or whatever it would just be sweet if the scangauge showed it
Old Dec 12, 2008 | 07:54 AM
SHG_Mike's Avatar
nope the scan gauge gets its "speed info" from the same source that that cluster does. however it is digital so that lends itself to be a bit more accurate
Old Dec 12, 2008 | 04:13 PM
mahout's Avatar
What should i get?
Assuming you have 08:
I'm with dave but I suspect only 195/50x15's will clear at your drop. 205/50 maybe but not real likely. 195/55x15 out of it.
09 you'll probably be fine with 205/50x16 on 41 mm offset 16x7 wheels.
Old Dec 12, 2008 | 06:28 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
195/50/15's are best.
Old Dec 12, 2008 | 07:21 PM
redrumm's Avatar
.....agree'd
