Will 4x100, 16x7 +45 rim fit
Old Dec 17, 2008 | 08:01 AM
hanzo's Avatar
Will 4x100, 16x7 +45 our Fit?
Old Dec 17, 2008 | 08:17 AM
BakedCookies's Avatar
with ease... I plan to push a 205/50 16" on a 16x7 +40 with the aid of camber bolts and drops springs it will just barely squeeze in.
Old Dec 17, 2008 | 07:32 PM
the gene's Avatar
I've got 16x7 (+24mm) on all four corners on my '09... works fine with some camber.
Old Dec 17, 2008 | 07:33 PM
kelsodeez's Avatar
UNBANABLE
hand to the face.
Old Dec 17, 2008 | 09:08 PM
JDMchris.com's Avatar
I run THIS
i think what u ment kelso was, FACEPALM
Old Dec 17, 2008 | 09:14 PM
kelsodeez's Avatar
UNBANABLE
exactly! hahaha
Old Dec 17, 2008 | 10:00 PM
JDM_DOHC_SiR's Avatar
Question
Have some pic`s..??? I have got to see this on the front.. the rear might be OK but flush up front....??
Old Dec 17, 2008 | 10:51 PM
I run THIS
i dont know if its these wheels:
or these:
Old Dec 17, 2008 | 11:04 PM
Question
It Might be the BBS ones.. but flush.. up front ??? .. .. maybe a little poke up front... not buying it unless he has some cRaZy Camber up front..
Old Dec 17, 2008 | 11:18 PM
bryanfor311's Avatar
doesn't messing with the camber severely effect tire wear and life?
Old Dec 18, 2008 | 12:49 AM
victorSCP's Avatar
hand to the face.
is that a yes
Old Dec 18, 2008 | 08:05 AM
or these:
got to be the top ones, since the bottom ones are photoshopped on, well i guess you can fit any offset in photoshop
Old Dec 18, 2008 | 08:06 AM
yes it can, but improper toe will kill a tire a lot faster.
Old Dec 18, 2008 | 05:59 PM
zyl8tr's Avatar
I have a +42 16x7 and I rub during hard turns. That may be because of my 205/50/16 tires tho.
Old Dec 18, 2008 | 08:49 PM
are you using camber bolts? I plan to use them and an aggressive lowering spring to tuck in the +40's w/ 205's
Old Dec 18, 2008 | 10:33 PM
zyl8tr's Avatar
Yes I am using camber bolts with Tanabe DF210 springs. I can only muster 0.9 negative camber.
Good luck with the +40 offset. Maybe if you go 195/50/16 it might work perfectly.
Old Dec 19, 2008 | 10:58 AM
That sucks, too bad I already bought the tires, got those 205/50 Goodyears when they were $49 a piece on TireRack.com
Old Dec 19, 2008 | 11:10 AM
Lightbulb
You can make them work... up front but you`ll need 2 sets of camber bolts to get in the -1.5~1.8 Range...zyl8tr only used one set and he was only able to get -.9.... so it might work..
Old Dec 19, 2008 | 11:40 AM
So you are saying the top camber bolt would pull the hub in, then use another camber bolt on the bottom to push the bottom of the hub out more?
Subaru's had a regular bolt in the bottom, and a camber bolt in the top from the factory, that I always just set to max negative, then had an alignment done.
Old Dec 19, 2008 | 12:51 PM
Thumbs up
Yep......
